For Eight Ball Champ when a playfield lamp never turns off, what is typically the cause? Also I have about 6 lamps that wont turn on and for two of them it turned out to be a cold solder joint on the negative (ground) cable. for the other four, after confirming the bulb was good, I checked the ground and it was fine as well. Is the issue usually an with the lamp drivers on the 6803 Control Board for both of these issues (never turning off and never turning on)?
Thanks,
Chad
