(Topic ID: 124316)
Lamps fade out after power up on Who Dunnit
By clg
9 years ago
  • 7 posts
  • 3 Pinsiders participating
  • Latest reply 9 years ago by clg
#1 9 years ago
I just picked up a Who Dunnit yesterday. When I power it up all the inserts work but are maybe a bit dim. After a minute or so they grow dimmer and then about 90% go out. The ones left vary each time but tend to be located on a particular light board as opposed to a particular row/column on the lamp matrix.
Sounds like the power supply is dying but I am embarrassed to say I don't quite know what I should look at hence I would appreciate any advice!
Cheers
#2 9 years ago
OK played with it some more and the 18v test point reads 18v so it must be something downstream from there I think?
#3 9 years ago
I may well figure this out on my own if I keep this up... So the test point is 18v but J137 is not showing anything so whatever it is must be between the testpoint and J137 and would have to affect everything so not a transistor... Sound right? I need to pull out a schematic
#4 9 years ago
Maybe a data problem, reseat the ribbon cable from CPU to PDB
#5 9 years ago
The lamp columns should be strobing the 18V very quickly.
The lamp rows should be pulsing to ground very quickly too.
With your logic probe...
Columns...
U11, pins 11 thru 18 should be strobing.
U10, all pins except 1, 10, 11, and 20 should be strobing. Some are input from the data bus, some drive the ULN2803 at U11.
Rows...
J124/5/6 pins should all be strobing low.
Chris Hibler -CARGPB #31
http://www.Team-EM.com
http://www.PinWki.com - The Place to go for Pinball Repair Info
#6 9 years ago
I need to pick up a logic probe I have been getting help from a friend with one on another game so I actually get what you are saying Chris thanks!
I did a quick check this morni\ing reseating the connectors and it may have resolved the issue, lights stayed on for about 1/2 hour before I had to go to work. It never made it more than a couple minutes before. But it could be because it was a bit cooler too. I will give it a more thorough test later on today.
Thanks for the help!
#7 9 years ago
Had it going for an hour and a half and all good. Calling it resolved.
Playfield - Plastics
$ 9.95
3,970
Sussex, WI
$ 100.00
$ 649.95
Pin Stadium Pinball Mods
Yucaipa, CA
$ 37.50
$ 26.50
PinSound
4,899
West Chicago, IL
KAHR.US Circuits
Arcade Upkeep
$ 54.95
This page was printed from https://pinside.com/pinball/forum/topic/lamps-fade-out-after-power-up-on-who-dunnit and we tried optimising it for printing. Some page elements may have been deliberately hidden.
