The fuses were the very first thing I inspected and replaced if necessary when I got the machine. They are all the proper rating (to their credit, the PO's had mostly the right ones except a 3A in the solenoid block - which was the only area I had trouble with due to the faulty left pop bumper circuit - I have since fixed it and am using the proper 2.5A there).
OK, pics you requested: 2400px wide in full-res...!
^ Note the scorching on the Anode pin 3, on both S5 and S7. During the diagnostic "all flash" controlled lamp test, when the lamps would flash I would see a similar flash on those pads. S7 was MUCH worse. One of those "am I really seeing this?" things I kinda stared at for several seconds. I do not know if anything was amiss before I started the test.
Note I replaced the previous direct-mount 7406 chips, with sockets and new chips. Light glare seems to indicate I don't have them both level at identical Nth degrees, but they are solid.
At this magnification it would "almost" seem like the top anode pad on S5 is touching the trace next to it... but when I check this, there is no continuity.
You may notice the discoloration near U54: I accidentally began desoldering that row, but caught my mistake after a few pins and resoldered them. Post screw-up, it tests identically to U53, and FWIW I did not notice a "column" issue (granted, I probably didn't have time to make sure).
I did run the test long enough to see that Row 8 was STILL locked on.
I labeled the areas with pencil (afterward) since this back view is inverted.
I'm not a pro but I think my solder work is OK? I have checked all traces for continuity / suspected possible shorts, and haven't noticed anything.
Postmortem Diagnosis
Here is what I know post incident:
- Q38 tests bad now - whether cause or effect I have no idea... at any rate it is not logically related to S7/S5 though it is physically very close.
- SIP S19, 6.7 Kohm, pin 8 (from the left) now tests low, ~5.6 Kohms. (this is also for that blasted Row 8... BUT I know this was good before since I tested everything I could, including this specifically).
- All n4001 diodes indicate OK (on board). All discrete resistors are OK.
- Very strange: 7406 #U59, pin 4 only tests at ~.2xx when in the socket. Outside the socket, it is fine. Both chips test the same off board; same behavior with U59 socket4 if I swap them. I can't discern why this would happen or what could be wrong with the socket. I do realize this is schematically related to S7... but is it cause or effect or WTF...?
- The 3W power resistors are all testing .8 ohms... not the rated .4 ohms. I am second-guessing myself on these components now. I know I tested them all originally, and they were all the same. So IF they were this out of spec previously I didn't catch it (since most of the rows were OK and I was looking for obvious outliers given too many numbers in my head and on paper and.... sigh). How serious is this aspect? I would surmise the higher resistance would be a "better" failure than going open (might just dim some rows, right?), and since they are all the same is it really a "failure" or just age/wear... again, most rows are OK...? Replacements seem pretty hard to find....
My tests are all with a DMM in the appropriate mode. I don't have a logic probe (never had a conceivable need for one until... now....?)
To help anyone for reference, here is how the components break out from the Manual Schematic. Conveniently, the Q and S component numbers correspond to the rows! The 7406 pinouts are a little more "random":
Row....Q#.....S#....U#.....Upins
1........31......1......58......3-4
2........32......2......58......1-2
3........33......3......59......12-13
4........34......4......59......1-2
5........35......5......58......10-11
6........36......6......58......12-13
7........37......7......59......3-4
8........38......8......59......10-11
Thank you to anyone who can help. I'll be licking my stupidity scars from this one for a while...
