New (to me) game. Data East Jurassic Park.
Row 2 lights are out (Q73). This was clearly replaced and the work was a little messy so I was hopeful cleaning it up would fix the issue. In circuit it tested slightly out of spec to the rest of them. I removed it, cleaned up the area and replaced with a TIP 102. No go - entire row still out.
I ground the metal tab of Q73 during test and the entire row lights up. I also connected another row (Pin 1 of CN5) to this row (Pin 2) and the entire row lights up in test. This leads me to conclude the Q73 is fine. I checked the ceramic resistor to make sure it was on the board and had continuity throughout per a guide's recommendation.
According to the same guides my next step is the Q82 which is a 2N5060 (NTE5400) silicone controlled rectifier or the PIA. I don't have any of these in my stash but I can order some.
Is there anything else simple I'm missing here given the troubleshooting I listed above? I don't believe it is anything else downstream right given the row lights up when jumpered to another row?
