(Topic ID: 189125)
Lamp problem (Medusa, Bally 1981)
By nibre
  • 9 posts
  • 6 Pinsiders participating
  • Latest reply 3 years ago by acebathound
#1 3 years ago
Some insert lamps are on all the time and some are never on (they are not broken). When I look at the lamp driver board, the transistors in question even look broken (see image).
Is it as simple as this? I replace every transistor where there is a problem.
Should I measure the transistors first, and if so, do I check the resistance or use the diode test? Is it ok to do it while the board is still connected?
Could other components be broken? Can there be another underlying problem? How can so many transistors be broken at the same time?
#2 3 years ago
How many lamps are on and how many are not? Do they work in diagnostic mode? (Flash on an off). You have corrosion on some of the transistors in the photo. This could be the source of some of your problems. Also did you replace the connectors on the lamp board, both male and female? Finally did you check the light sockets themselves?
Don
#3 3 years ago
Quoted from nibre:
Pretty much.
Quoted from nibre:
My guess is they did not break all at the same time. If they did, I'd look for another problem. I just replaced a bunch on a project I'm working on and the location of the board makes them very susceptible to alkaline damage from the batteries mounted above.
#4 3 years ago
On bally boards the transistors will need to be tested 2 ways.
For the larger square transistors:
1: On the diode test.
Put the black lead of your meter on the outside "cathode" leg (labeled "C")
Put the red lead of your meter on the outside "gate" leg (labeled "G") Your meter should read .4 to .6 volts.
Swap the meter leads. Now the meter should read 1.4 to 1.6 volts.
2: On the continuity test. Test the other sets of legs and make sure they are not shorted.
On the smaller transistors:
Put the black lead of your meter on the "cathode" leg (labeled "C")
Put the red lead of your meter on the center "gate" leg (labeled "G") Your meter should read .4 to .6 volts.
#5 3 years ago
The green gunk is from battery damage.
Remove and replace them is highly recommended.
Also clean you board with a 50/50 sollution of vinigar and water, just like what you should do with the mpu.
Check the bottom traces for continuity from thyristor to connector.
Good luck....
#6 3 years ago
Thanks for all the advice!
The machine was in this condition when I bought it and I don't know its history.
I have ordered components and will do the replacements and cleaning in a few days.
There is a new battery in place (see image below). Is this a type that can leak in the future? Are there any other, safer solutions?
#7 3 years ago
Yep, this is the kind of battery that can leak over time.
Actualy it's not a normal battery (alcaline), but a rechargeable battery (nickel-cadmium).
The safer methode is a memory cap of 1F (not uF).
http://www.pinwiki.com/wiki/index.php?title=Bally/Stern#Installation_of_Various_Battery_Eliminators
Peter
1 month later
#8 3 years ago
I have replaced the transistors and now the lamps work as they should. I haven't replaced or moved the battery yet.
#9 3 years ago
Quoted from nibre:
Yeah I'd cut that battery off ASAP.
NVRAM is $15 for a single module from a few sellers.
I sell them @ https://pinside.com/pinball/market/shops/1030-pinitech/00316-5101-nvram-battery-eliminator-for-high-score-save
I'm not usually advertising a ton when people post things like this, but your board is so nice compared to most that I'd really recommend going with someone's NVRAM product and ditching the battery so you can keep it that way. Any time I get a board in that looks like that, doesn't matter if the battery looks like it's been replaced recently.. it's gone! They're ticking time-bombs and anyone's guess when they decide to leak. Even brand new alkaline batteries leak often enough when their expiration dates are 5+ years in the future.
5,200 (OBO)
Phoenix, AZ
$ 149.95
Allteksystems
$ 139.00
Third Coast Pinball
