(Topic ID: 251146)
Lamp matrix issue WPC 89
By monkfe
5 months ago
  • 6 posts
  • 2 Pinsiders participating
  • Latest reply 5 months ago by monkfe
    #1 5 months ago
    So I'm having an issue with three rows out on my taf (using a seigecraft lamp test board here so the issue is on the board)...Checking the Tip 102's three are not lighting up on my logic probe. So when I go back to the 74LS74 I'm checking the outputs at the ones that are working to confirm against the three that are not right...I get to U10 pin 13, I get nothing. (although this is not control the transistor that's giving me a problem) Schematic shows pin 13 connected to pin 1 via board trace. I check all my other 74's and they're all connected (ohm/continuity check) and giving an output. So I had replaced these with sockets and now I'm thinking I screwed up the trace somehow and now I remove the socket again only to find that pin 13 goes nowhere...just simply a single trace on the board both sides? Anyone have any idea how this is? The lm339 in this circuit is an overvoltage cut off correct? How do I determine if its shutting off the 74LS74?
    #2 5 months ago
    With power off try reseating the short/wide ribbon cable on both ends that connects at the MPU and at the driver board. Sometimes when you have multiple things out like 3 rows of lamps, you may just be missing a signal coming from the MPU.
    #3 5 months ago
    Quoted from monkfe:
    On the driver board, U10 pin 13 is also tied to U10 pin 1, U11 pin 1 and U11 pin 13.
    #4 5 months ago
    Quoted from PinballManiac40:
    I'll give it a look in the morning....
    #5 5 months ago
    Hoping for a good result.
    #6 5 months ago
    Yes that was the issue...two end pins on the mpu were just slightly bent, I'm guessing they weren't making contact...all is well now....Thanks gents...
    Great American Pinball
    $ 18.25
    The MOD Couple
    $ 27.00
    $ 18,500.00
    www.retroarcade.se
    £ 32.00
    $ 29.95
    $ 76.95
    $ 49.95
    $ 40.00
    Arcade Arts
    $ 49.00
    $ 19.99
    Playfield - Plastics
    Docquest Pinball Mods
    $ 24.95
    $ 52.95
    $ 59.99
    Hardware
    Chroma Pinball
    $ 137.00
    Rubber/Silicone
    Scandinavian Pinball
    $ 18.95
    $ 95.00
    M&M Mods
    $ 40.00
    Apparel - Unisex
    Pinball Wheezer
