Hi all.
I need some help with diagnosing a lamp issue on JD. All lamps on column 4 are not working. All of these lamps are on the large lamp board in the bottom centre of the playfield. I have checked all of the bulbs are actually working - they are. I have checked all of the diodes and solder joints on the lamp board - all good. Solid 18v is present at TP8. I have checked for continuity from J137-4 in the backbox to each of the lamps - all good. I have also checked the transistor at Q95, which controls this column - all good. I also did the jumpered lamp socket test (between J133 and J137), and all columns lit the test lamp properly.
I'm not sure where to go with the troubleshooting from here. I suspect that I need to start looking at the ICs on the power driver board, but I do not have a logic probe.
Thanks for any help.
