Hi
The left side castle inserts on my MM are a little dim/inconsistent. I think it has to do with the right side wire on my board connector. As you can see it isn’t pushed all the way into the connector. How do I go about pushing the wire in/fixing it?
Also, can these connectors just be pulled off the board? It doesn’t look like the pins are soldered onto the underside of the board.
Lastly, what are these connectors called?
