I'm frustrated, the schematics in the LAH manual don't match reality.
The issue: the ripper coil completely burned. I replaced it. Checked Q13 and Q7 on CPU per schematics and they're ok. Powered up and started running through diagnostics.
Ripper still not working. Noticed magnets are out too. Checked fuses, since I previously forgot. Found fuse F9 was blown. Yay.
Replaced it and found F9 blows on boot. Boo.
Tested Q1 on PPB and found it to be shorted. I think this explains the ripper still not working, maybe also why the coil previously overheated and burned.
The frustration I'm having is that there are no references to the magnets in the schematics, and the schematics also only document F1-F6 on the PPB board, but not F7, F8, F9, which are mentioned in the manual, but absent from the drawings. I'm thinking schematics are for an earlier generation or generic drawings while the board is specific to LAH.
I'm trying to figure out if there are other parts I need to test for the magnets part of the issue before I place an order for the 1 blown TIP transistor.
Has anyone ever had the magnets go out on their LAH, and if so, how did you trace the problem?
