Working today on a Last Action Hero that suddenly lost both flippers??? I have checked the EOS switches as well as the cabinet switches cleaned the contacts and checked that they are all properly adjusted. Fuse F5 was blown on the PPB board as was F5 on the power supply. Replaced the fuses thinking I should see some kind of results but still no flippers & the new fuses do not blow. I have also tried jumper wires across the EOS switches and the cabinet switches but still cant get anything out of the flipper coils. Both of the LED's on the flipper control board under the playfield light when the flipper buttons are depressed for a second but do not remain lit if button is held I think this is normal? I have checked for voltage at the coils and with the game on in play mode and flipper button is depressed I get a spike of around 36 vdc that settles at around 4.7 vdc when the button is held down. The flipper board the game is running on is a 520-5070-00 and the board has had a lot of repair work around the fuse holders. I do measure good continuity across them though. I also tried a used and untested 520-5033-00 flipper board from a data east star trek but that did not work for me either.
