Shopping a friends LAH. Can someone tell me the correct fuse values for the ones under the playfield and in the Two boards in the lower cabinet? Don’t see them listed in the manual.
Thank you.
All 3 magnets are 3A SB. The small board at the front bottom of cabinet is F1 is 2.5A SB, F2 is 2.5A SB and F3 is 2.5A SB. The larger board in the middle lower cabinet is F1 is 3A SB, F2 is 4A FB, F3 is 3A SB and F4 is 3A SB.
Where is the crane fuse located?
I could not find these values in the manual. I check the fuses that were in the pin.
Thank you. I never assume the fuses in a used pin are correct. This is the first thing I check when I bring a game home. They always have at least one that is over fused.
I found the fuse values for the flipper control board in the schematics. They are all 3A. I assume SB. You have a 4A in F2 which should be changed.
The crane fuse is behind the crane motor.
Thank you very much. I have put the info in the manual.
Now to annotate the problems with the rubber chart.
This page was printed from https://pinside.com/pinball/forum/topic/lah-fuses and we tried optimising it for printing. Some page elements may have been deliberately hidden.
