(Topic ID: 220629)
LAH flippers activate ripper/ ball lauch
By Alwaysbrokenpins
5 years ago
  • 8 posts
  • 6 Pinsiders participating
  • Latest reply 2 years ago by OTCHU
    #1 5 years ago
    I just pick up up a LAH that was non working. I stripped the playfield down and cleaned it. replaced all fuse clips. New Bridge rectifiers (all). Checked all fuses. Reflowed solder.
    Game boots fine and All looks well but still having a few issues.
    -will not eject a ball
    -when I push flippers the ball launch and the ripper solenoids fire (but activate very weakly) { <---This is the weirdest one for me }
    - the ripper does not fire during the "ripper" test
    - Also of note during diagnosis test:
    -coil fire tests no coils fire until what seems to be one cycle has run... then the backbox lights flash once then the coil test begins again... and then only some coils fire (pop bumpers, kickers near flippers, few others).
    -during lamps test. All lights display and flash during that test but the lamp "row" and "column" test... nothing happens.
    Seems like a few issues here But the most confusing as the flipper ripper/Ball launch problem
    2 years later
    #2 3 years ago
    I'm having the same problem. My flippers dont work but instead activate the Ripper kickback. My trigger/laucher also isn't working. This was fine before transporting the machine home. Did you ever figure out the problem or solution.
    Anyone recommend where to start?
    #3 3 years ago
    Quoted from Grips:
    Reseated or checked for a broken wire on MPU board connectors CN8 and CN10? Those are the switch matrix inputs.
    #4 3 years ago
    Left flipper will launch ball. I posted this question in the LAH forum when I bought mine. It should not fire other coils though.
    #5 3 years ago
    Quoted from PinballManiac40:
    I took a quick look and all seems fine. Thank you for your suggestion. I will try to troubleshoot further tomorrow. Sucks as im new to this and the machine was working before I brought it home. I hope this doesn't scare me away from the hobby.
    thanks again!
    #6 3 years ago
    After more digging I found out the following issues:
    Magnet, laser kick "ripper", Auto launch, Right VUK, Right Scoop all fail to function. Other than the laser kick "ripper", all share the same yellow-violet wire. The ripper has a violet-yellow wire. The 5a F5 fuse was blown and when replaced it blew again. The Flippers don't function and still activate the ripper coil but at a lesser force. I can't seem to find any crossed wires. I am not sure what to do next. Kind of overwhelmed at this point.
    Anyone have suggestions on what to look for next?
    #7 3 years ago
    Granted that the ribbon connectors are installed correctly (and the connectors themselves are good) in addition to connectors CN8 + CN10 installed correctly and in good shape, i would check *all* of the switches and their diodes on switch row 8 since the problems all seem to have a common thread there.
    Screenshot_20210311_095835_com.google.android.apps.docs(1).jpgScreenshot_20210311_095835_com.google.android.apps.docs(1).jpg
    The auto-launch button, the ripper, and the right flipper button are all on that circuit. It's important you check the other switches on that row as well, because a shorted diode, wire, or some other problem with *any* of the switches on that row can create havoc elsewhere with switches on that same row.
    So I'd suggest checking all those switches (numbered 8, 16, 24, 32, 40, 48, 56, and 64) and verify the diodes are firmly connected and have correct orientation, and also that the wiring is correct at each one and firmly connected as well. Make sure none of the solder lugs on the switch or wires or diode legs are contacting anything nearby.
    Did you reflow the header pins for cn 8 and 10? If so, check for any possible bridging between pins on the solder side of the board.
    8 months later
    #8 2 years ago
    Any update ? I have the same problem .. flipper don't work and ripper activate when use flipper... and trigger doesn't work also
    This page was printed from https://pinside.com/pinball/forum/topic/lah-flippers-activate-ripper-ball-lauch and we tried optimising it for printing. Some page elements may have been deliberately hidden.
