After about 2 or so years, I finally have my Firepower pinball machine. Took me all that time to move, have another daughter, get through other parts of life before I started looking for one again. A really nice member of the forum sold me what I consider to be a very nice working condition machine for a very reasonable price. I was unbelievably excited because this is my first, and will be my only pinball machine.
Now I am in the process of deciding just how much I want to do with it, and how far I want to go towards rejuvenating it. I know that on the open market, this will not fetch a price worth what I may eventually put into it, but as people say it is a "labor of love."
The reason I called this topic a rejuvenation instead of a restoration is that I am not sure how far I want to take this. Do I clean it, level the inserts and touch it up, or do a whole play field restoration? I don't know if I can do the latter, but am not sure what I can do to at least make it originally playable (i.e. the inserts don't slightly deflect the direction of a free-moving ball).
The previous owner did many major board fixes already (replaced capacitors, replaced the 40-pin connector, made the multiple resistor modification, put in a new speaker). He also installed full LEDs throughout. So far, I have:
-Adjusted many roll over switches so that they function consistently.
-Replaced the 1-6 target "Firepower" stickers.
-Am in the process of rebuilding the ball shooter with new parts.
-Cleaned and adjusted the three ball switches and return ramp (which was filthy).
I am also awaiting new parts to replace the plastic flippers.
So, after all that, I'll post some pictures so you guys can see what I have, what condition it is in, and what suggestions you have.
Here is the play field from afar:
Here is the underside. Very clean, I must say:
Here are the replacement target stickers (with new foam backing):
Here are a few shots of the paint wear on the field. It is overall not terrible, but you can see whereto paint is worn, cracked, scrapped away where inserts have cupped, etc:
IMG_3323_(resized).jpgIMG_3321_(resized).jpgIMG_3322_(resized).jpgIMG_3320_(resized).jpgIMG_3326_(resized).jpg
The upper portion of the play field is either worn or dirty, and I am leaning towards dirty:
Finally, the area under the front panel was INCREDIBLY dirty. You can see from just a simple cleaning on the right how much dirt stood to be removed:
That's all I have for now. Please, let me know what you'd do, what you think can be done, and what you'd suggest. Thank you!
