Hey @sennap1, I presume you probably figured it out (or worked around it) by now -- but in case you or someone else needs it, since I just finished refurbishing mine, here is a list are where they go:
Technically, there are only 4 required, at the following locations.
-- 2 support the round plastic above the center kickout hole
-- 1 supports the long plastic on the left; it was two tall metal standoffs so you need the tall post here
-- 1 supports the long plastic on the right; it was two tall metal standoffs so you need the tall post here
NOTE: If you decide to swap out the other 11 with the standard posts (like I did), just be aware the screws are longer so they might start to poke through the bottom of the playfield. You can trim the tip off the end of the screws with bolt-cutters to prevent this.
The remaining 11 were at the following locations:
-- 2 supporting the arch/gate at the bottom end of Knockout alley
-- 2 each supporting the red rollover lane guides (8 total)
-- 1 supporting the other end of the arch/gate attached to the right-most red lane guide
