(Topic ID: 235401)
Knocker not firing on Flash.
By crujones4life
5 years ago
#1 5 years ago
What it does is kind of quietly hum when it should fire...vibrate the tiniest bit.
4.5 ohms at coil
Verified continuity from brown and blue wire on coil all the way to driver board.
Tried it in game and during solenoid test.
I still have to check the diode on the coil.
If that tests ok do I just assume the transistor is bad? Is there a way to test it? What else could it be?
#2 5 years ago
Is the knocker froze up in the plastic sleeve? Can you move it back and forth freely?
#3 5 years ago
It moves back and forth freely. Actually it fired once yesterday during all the testing. Was weak though.
#4 5 years ago
I made a short clip if anyone thinks they can help diagnose I can text or email. Thanks!
#5 5 years ago
I would maybe try changing out the coil with one that works. I guess that might tell you if it was the coil is bad or not
#6 5 years ago
Coil measures 4.5 ohms and diode measures 0.7 (well 700 on my meter I assume that is 0.7 as no decimal displays when set to diode setting).
Pretty sure coil should be good with that reading...right?
#7 5 years ago
I guess pull the driver and reflow edge connector? Not sure what else to try. Besides replacing the corresponding transistor which is fine but I have to order it.
#8 5 years ago
I have the exact same problem with my Flash. Replaced coil, sleeve, and still no succes. When it fires I just get a weak bump.
Would love to know the solution you find.
#9 5 years ago
Just reflowed the edge connector and transistor...transistor tests good verified by testing nearby identical transistors. Will put back in and retest.
Any other ideas appreciated.
#10 5 years ago
Plugged it back in and no change...any ideas at all are much appreciated. Thanks!
#11 5 years ago
How much DC voltage is at the coil when idle? Should be between 28-38V.
#12 5 years ago
Quoted from mwsmith:
You know I had trouble measuring the DC voltage on not just that coil but all the coils. Numbers always bouncing around. The numbers were kind of all over the place but hovered around 19v DC...since all the coils I measured are similar I am thinking the voltage is there even though I can't get a good reading for whatever reason.
I connected test lead to negative side of coil and grounded it to metal side rail. Still just get the humming and light vibrations...
#13 5 years ago
Can a coil still be bad with a reading of 4.5 ohms? Diode is good.
#14 5 years ago
Quoted from crujones4life:
Marcos coil labels have the DC resistance printed on them. Looks like your 4.5 ohms is good for a 23-900 coil.
#15 5 years ago
So is it even possible for the coil to be bad with that reading? What's weird is that it responds with light humming and vibrations. Any previous bad coil I have had did nothing at all.
#16 5 years ago
The coil at 4.5 ohms is OK, so is the diode with 0.7V drop. Does the knocker work if you short its driver transistor collector (tab) to ground? If it works then, you have a bad transistor - either the power transistor or pre-driver. If not, then check connectors for bad contact.
#17 5 years ago
Quoted from Tuukka:
I tried shorting the coil directly to ground and it still didn't fire. (Post #12). I verified continuity from coil to driver board as well. I guess maybe I can check the driver board chips? I thought shorting the coil to ground bypassed everything else so long as it is getting voltage. Is that not correct?
#18 5 years ago
show a picture of your knocker assembly. You can assemble something wrong and it makes the coil really weak.... i forget exactly why tho.
#19 5 years ago
20190204_191704 (resized).jpg20190204_191704 (resized).jpg20190204_195329 (resized).jpg20190204_195329 (resized).jpg
#20 5 years ago
Take it apart and clean the knocker and sleeve with alcohol? But iam new and don't know much.
#21 5 years ago
Plunger slides through the sleeve nice and smooth. It's pretty clean.
#22 5 years ago
Now that I see the picture I remember.... the plunger rod being installed upside down is what I was thinking of. Looks like you got it right, but make sure the nylon tip of the plunger is going to strike the top.
#23 5 years ago
I'm sure this doesn't help, but I have never even heard the knocker fire in my Flash because it only gives sound effect when set up for free play. You have your machine set up for coin op, right? My understanding is that William's machines of that era did not use the knocker at all in free play.
#24 5 years ago
Quoted from Calfdemon:
That's how my Firepower works. You wont here the knocker on free play.
#25 5 years ago
Williams SS knockers seem to almost never work and when they do they make a dull thud you hardly notice.
I don't bother trying to fix them or make them louder. Just not part of the early Williams digital experience for me.
#26 5 years ago
If you tried grounding directly at the coil and it still did not work, there is a problem getting +24V power to the coil (the red wires).
#27 5 years ago
Take it off Free Play, it should fire every time you add a credit, If memory serves me correctly.
#28 5 years ago
Game is not on freeplay. I didn't even know that was possible...lol.
Edit: I am pretty sure the manual states credits can be added from 1 to 99.
Are we sure Flash has free play?
Regarding the voltage...I for some reason cannot get a steady voltage measurement on any coil. Numbers bouncing around everywhere. Digital MM new battery. It is definitely seeing some voltage as it hums and vibrates. The readings were similar to flipper and drop coils so assumed (lol) was getting correct voltage. Will try to measure again.
#29 5 years ago
On my system 6, I think if you set the maximum credits to "00" it will go into free play. Something like that.
#30 5 years ago
Have you checked for cracked solder at the pins on 3J3 on the power supply board? (lower left corner) Pin 7 at 3J3 feeds the 28V to the knocker & coin door coils. Also check the plug for burnt or corroded contacts.
#31 5 years ago
Thanks! I will check this out tomorrow.
#32 5 years ago
Solved! You guys ready for this one? The plate that the plunger rests on is magnetized! Feck!
My "fix" was wrapping the plate in electric tape. I ain't replacing the assembly. Thanks everybody for chiming in!
#33 5 years ago
Well if barakandl hadn't flagged it as problematic, ironically I would have suggested flipping the plunger so the nylon tip prevents the magentic attachment.
Congrats on figuring this one out.
#34 5 years ago
LOL! Congrats on that find! I'm gonna make a note on that one.
#35 5 years ago
Just remembered something. The bracket is supposed to have a rubber on the bottom for the plunger to rest on.
If you want a louder knock, try the mod I used on my Flash: https://pinside.com/pinball/forum/topic/knocker-sounds-weak-on-gottlieb-system-1-machines#post-3716952
#36 5 years ago
Yeah that rubber piece would have kept the two metal pieces from becoming magnetized...probably been missing a long time.
950 (Firm)
Woolwich Township, NJ
Tools
Pincoder Store
2,100 (OBO)
Milan, IL
$ 27.95
400 (OBO)
Green Brook Township, NJ
1,300
Allentown, PA
$ 170.00
Displays
Digipinball Shop
$ 9.95
This page was printed from https://pinside.com/pinball/forum/topic/knocker-not-firing-on-flash and we tried optimising it for printing. Some page elements may have been deliberately hidden.
