I wanted to add some highlight color/brightness to some dark play field areas on this Klondike. The new plastic from Pinball Rescue was crying out for additional light under the tree without overpowering the new white reel score emblems (thanks Mr.Pinball). I placed a Comet 6 volt three-light green strip here.IMG_1343_(resized).JPGIMG_1343_(resized).JPGIMG_1341_(resized).JPGIMG_1291_(resized).JPG
Then the to the dark center play field where I could never determine when I was in a higher score range from reel alignment.After cleaning/polishing the inserts from the bottom I installed a Comet Supreme Brightness non-ghosting bulb in position 1,a slow blink warm white in positions 2 and 3,a fast blink natural white in position 4,and a fast blinking color changing bulb in the Special. Under this a 6 volt 7 light green strip was placed and wire to the slingshot. Basically the green center positions are always on and blink when the reels line up. I could not obtain a good picture but it came out great.IMG_1340_(resized).JPGIMG_1342_(resized).JPG
I also place a Comet 3 green strip under the apron to light up the flipper area a little. 2 Comfort Bright bulbs under the slingshots, a slow and fast blink under each upper side plastic,and two comfort bright under the pop-up post,and it was done. I did not like the LED lights under the side lane guide plastics( thanks PBR) since they looked an ugly green,they stayed traditional.
