Milton, just catching up on this thread.
If you look at the bit of schematic that Pin-it posted and the fact that you are stepping up to position 9 on the ball count unit (remember there is also a zero position 10 in all). I’m suspecting the coin RE is not de – energising at the right time. The Coin Relay needs to de energise after the first cycle of the score motor which is 180 degrees. Check all the switches under the Coin RE coil, one of them may be keeping the Coin RE energised after the first cycle.
** Also check the SW on the score motor (3D) responsible for de energising the Coin RE coil (3 ball/game mode), in fact I would check this one first. If you are in 5 ball per game mode, than it is the SW on the index cam (below the SW In my bit of schematic)**
Post edited by Chrisbee: Little more info added (3 ball v 5 ball)
