I checked the original battery and it was fine. I put in a new battery just to see but it still won't save any settings after I turn it off.
Quoted from PinballManiac40:Did you exit the menu before turning off the game?
Yes, I exited the menu and played a game. Then off and back on and back to factory settings.
Kiss seemed to have a bad track history of having bad SD cards. Maybe contact Stern to see what they say.
Stern confirmed that it is the SD card. I called Game Exchange and ordered a new one. It was $65 bucks.
Stern will usually send you a new card with code on it for free. But if for some reason they don't, cancel that $65 order...
Quoted from buffaloatx:Stern will usually send you a new card with code on it for free. But if for some reason they don't, cancel that $65 order...
amazon.com link »
When I asked Stern they said to get it from a distributor. If I got a new SD card how do I load the code on it?
I believe you can just extract the latest code directly to the new SD card and then install it back into your machine. Or you can copy the old SD card directly to the new card.
Quoted from 1iblind:When I asked Stern they said to get it from a distributor. If I got a new SD card how do I load the code on it?
I saw this exact problem before and it was the SD card. I would go buy a new SD card (good quality one like Sandisk). Try copying your old SD card to your new SD card.
Quoted from buffaloatx:I believe you can just extract the latest code directly to the new SD card and then install it back into your machine.
I don't believe this is true. You might need to get an image from a friend. Finally, there was a thread here about how to restore an SD card. I will see if I can find and post the link here.
Stern did'nt send me a free SD card after 3 years on route. Getting an SD card with code was a pain over the summer. JJ to the rescue, had a kiss pro on the sales floor, cloned me a copy. Cloning SD cards is not that difficult, theres even a youtube video. Lesson learned, cloned all my spike pins and made a back up card.
Quoted from Turtle:I don't believe this is true. You might need to get an image from a friend. Finally, there was a thread here about how to restore an SD card
I couldn't find that post here, but, you are probably correct about dumping a code up date on to the new card.
Here's something from Tilt that might help.
We just managed to recover a “toasted” SD card tonight. Originally DP had bricked itself during update, so we pulled the card from SW and updated to DP. After copying our working DP image onto a fresh SD we had two functional DP cards, but weren’t able to get a booting SW as the update to SW would throw an error about being unable to unpack the update. I popped one of the cards into a pc and went poking around. On partition 3 found the unpacked DP update image. On a hunch (and after backing up the card) I deleted the DP directory and only then managed to successfully update the card back to SW. I really wish we’d been able to back up the SW image before the initial SW->DP hackery
I've never tried this but here's the link.
https://pinside.com/pinball/forum/topic/spike-sd-card-recovery-image-beta
Quoted from Sborel:Lesson learned, cloned all my spike pins and made a back up card.
PSA of the year here. If you have a Stern spike system clone your SD ASAP.
