Should be able to adjust the bar that they rest on. Loosen some screws, set the height, then tighten. Been a bit since I did this, but that is what I recall from memory.
Are those replacement drop targets? If so, compare the length with the original drops. The only Bally drop target assemblies with height adjustment are the inline style.
Same length
There is no adjustment screw on this housing
The targets bottom out at and that’s how high they remain visible
I once reassembled a drop bank incorrectly and had this issue. Maybe double check your work? If you google, you can find an exploded view with details. My first guess would be the bottom plate might be installed upside down.
Quoted from tomdrum:Are those replacement drop targets? If so, compare the length with the original drops. The only Bally drop target assemblies with height adjustment are the inline style.
Ah, yes. That is the type of Bally bank I was thinking about that had that adjustment. Paragon.
Quoted from TheCnyPinGuy:Before I took them apart
I’ll Double check my work
Thank you
[quoted image][quoted image]
Okay I’ll pull it out and take another look
There has to be a reason why it won’t drop that 1/4 inch
This page was printed from https://pinside.com/pinball/forum/topic/kiss-bally-drop-target-bank- and we tried optimising it for printing. Some page elements may have been deliberately hidden.
