Played Kings and Queens Monday, game started up played 100%. Yesterday I went to hit the credit button and nothing. No lights came on, game dead as a doornail. Checked power cord and reciptical , plug is fine. Checked connections to the slow Blow fuse and the transformer, again all fine. Checked all 5 fuses, no issues, fuses were replaced and inspected with power on,, no difference. Bounce switch on door and main board are set correctly, no issues. Start or credit switch,, all good, ,no loose wires, solid solder connections, no wires look loose or disturbed. The only thing that comes to mind is the TILT assembly and that looked fine, ,The schematic shows a 115V Relay, don't see a tilt relay, maybe they are one in the same? The credit wheel has 11 credits, the last game I played I was killing it with specials I may have tilted the game trying to save it from the outlane. The TILT bulb in the backbox is out, I am assuming this. Also all 5 balls are in the balls played assembly and the switches in that assembly seem fine.
Any positive suggestions are welcome and appreciated. I'm telling you the game just sat there dark, it wasn't disturbed, and I deffinitley have juice in the cord. No lights on the playfield, inside the cabinet, or in the backbox are lighting up.
