(Topic ID: 223716)
Kings of Steel - Target switch question
By Misterek
1 year ago
  • 6 posts
  • 5 Pinsiders participating
  • Latest reply 1 year ago by Misterek
#1 1 year ago
Hi all. New pinball machine owner... Kings of Steel in very good shape - recently restored/refreshed by a local repairman. Kids have been enjoying pinball with their friends.
Target switch broke - main target in the center of the play field, large rectangle target. Leaf broke just below the playfield surface. Two pics attached (put a rubber band across two posts to keep the ball from getting stuck... let's the kids keep playing for now.)
1) any advice / assistance on finding and punching the correct replacement target switch?
2) i'm OK with a soldering iron but not an expert. is this repair something a rookie can tackle without creating more problems?
Thanks in advance for the advice!
Moderator - apologies if i've placed this in the wrong sub-forum
Chris
#2 1 year ago
The replacement switch target is A390-00017-0 but I couldn’t find this exact target when I restored my game. I’ll have alook at mine tonight and see if I can give you a better idea of the replacement part I used.
If you can solder a little you’ll be fine with swapping this out. It should be just 2 screws to remove and 2 wires to solder with a diode.
#3 1 year ago
Quoted from Misterek:
Youtube has lots of short how to videos. May help you improve your skills.
This might work for you - https://www.pinballlife.com/index.php?p=product&id=1761
#4 1 year ago
Quoted from LTG:
Take plenty of pics and take a note which wire is toward the negative band on the diode.
machine off , remove ball, place playfield in "service position"
#5 1 year ago
The same target was busted on my KoS when i had it (and the plastic above it too like yours). I also ccouldnt find the exact right part and I subbed something in that was close enough.
I think i found a used red square target at a pinball show or off a spare playfield.
#6 1 year ago
Thanks all. I found this one with the same dimensions as the original rectangle target.
https://www.marcospecialties.com/pinball-parts/515-6027-02
Appreciate the advice and suggestions... i'll be attempting this switch replacement myself.
THANKS!
Chris
$ 85.00
$ 79.95
Displays
PinballSolutions.eu
€ 3.95
Multigame
$ 44.99
PinballElectronics.com
$ 9.00
$ 119.95
Allteksystems
$ 79.95
Florence, KY
