First time this has happened on my K&Q. After playing a few games, I opened the front door and there was a decent spark from the top left of the door near the coin mechanism.
Luckily I did not get an actual electrical shock.
I turned it off. Could not see any frayed wires, nothing weird. No fuse blown. I turned it back on (pressing the credit button with a piece of wood ) and with the door open prodded around a bit with the piece of wood. Opened and shut the door a couple of times. No repeat.
Anyone has something similar? I know 120v goes to the door:
Which is why I took took Clay's advice and ran an earth connection to the door frame when I replaced the power cable). Is the coin chute switch prone to shorting? Should I simply disconnect all that part anyway (as its set to free play)?
Any and all advice welcome!
thanks
