All of a sudden game starts and ball not ejecting. The machine does not advance to 1 ball. The hole relay coil works manually but when it goes in hole it does not eject ball and continue to 1 ball.
If the game is completing the score reset and then it just goes quiet with the ball sitting in the outhole, there are two things to check.
First, check the switches at the motor 1C position. There is a switch on this stack that must be closed when the motor is in the home position in order for the ball return relay to energize.
Next, check the switches on the RESET COMPLETED relay. There is a switch on this relay that must be closed when the relay has tripped (score reset has been completed) in order for the ball return relay to energize.
- TimMe
This page was printed from https://pinside.com/pinball/forum/topic/kingpin-1973-help and we tried optimising it for printing. Some page elements may have been deliberately hidden.
