Hi I have a king of Diamonds . My problem is a few of the 50 point when lite rollovers are sometimes giving 150 points and 500 points . Any one had this problem. Thank you
I'm having the same type of issues with mine so I'm curious as to other peoples replies. I'm sure it will come down to cleaning contacts and adjusting gaps but, as an EM novice, I'm not sure which ones to look at first.
Hi look at all contacts can’t see nothing wrong it’s mind boggling. Thanks for reply good luck keep in touch if you find the issue
Does the problem only happen on the 2, 3, 6 & 9 rollovers or does it happen on 7 & 8 too? If it's just the first four have a close look at the 3/5 ball adjustment jones plug. Crossed or shorted wires there might fire the 100 point relay when it shouldn't.
/Mark
Hi I think I fixed the problem. Fingers crossed I cleaned score motor contacts and alternate relay . Putting glass back on then it will act up lol . Thanks guys
Hey Mark one ? When you go over rollovers and light goes out . And you hit the number on the roto wheel. Are you supposed to get points 10 thru Ace gives points but not numbers is that how your machine works .
Quoted from Ant16bar2:how can I check that resistor
https://www.google.com/search?client=firefox-b-1-d&q=how+to+check+resistor
This page was printed from https://pinside.com/pinball/forum/topic/king-of-diamonds-issue-1 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
