Hi,
King kool worked at show. Now, when I turn it on, the back box lights up and is in tilt mode. No Playfield lights, if you try to add credits or press start, nothing happens
Fuses all test okay
Hi,
Fuses all test okay
With the game on and the playfield up, try to manually spin the score motor. Sometimes this will kick it back into action..
Bounce switch (on score motor board), Anti-cheat switch (on coin door), make sure the score motor is at home position, and make sure the Control bank is reset.
Or, trip the Start relay (S) directly.
Check that all jones plugs are plugged in and not misaligned, especially since it worked at the show and now it doesn't.
Well never mind the flipper button response as I was thinking of my Em were you have no power until pressing the left flipper. You stated you have GI and are stuck in tilt.
I thought that was what mine did but no brain fart. I think mine has the kick in the biscuit off feature s well.
I should add that it was playing perfectly at a show, but broke at the show a day after I bought it.....
Quoted from Pinwow:I should add that it was playing perfectly at a show, but broke at the show a day after I bought it.....
Ha...now we both have a King Kool that doesn't work.
This page was printed from https://pinside.com/pinball/forum/topic/king-kool-help and we tried optimising it for printing. Some page elements may have been deliberately hidden.
