I am restoring a Gottlieb Aquarius. There are five kickout holes at the top of the game. They are supposed to give you anywhere from 100 to 300 points. The 100 point hole always gives you 100 points. The 200 and 300 point holes sometimes give you the correct number of points but frequently you get 100 or 200 points less than what you should get. I can hear that there are the appropriate number of pulses (2 or 3) going to the score reel and you always get 100 points then sometimes you get the correct number of points and sometimes the score reel rotates forward a bit then "falls back" to the last position. I thought it was a score reel problem but I cleaned them and adjusted the score reels and it did not solve the problem. Also, just to be sure, I hot wired the 10 point score reel coil to the 100 point score reel coil and when I actuate the game's 50 point relay the 100 point score reel work fine and always reflects all five pulses. It appears the problem is with the kickout hole relays, any idea of how they may need adjusted? Cleaning the relay contacts did not solve the problem. My schematic and manual do not show what the individual contacts within the kickout relays actually do.
