I just used novus for the first time. Im not sure how long I should wait before applying blitz wax.
Quoted from bigehrl:
carnauba wax has a half life of 24.5 yrs. better hurry up!
I think he is asking how long should he wait for it to dry and then apply wax?
I didn't know you had to wait any longer than required for it to dry (couple minutes). I'll be interested to see people's opinions on this.
Edit: which novus did you use?
Quoted from brainmegaphone:
I used novus 3, 2 and 1. I read that novus has solvents in it. I've done some guitar finishing and I know that the solvents have to flash off before going to the next stage in the finishing process.
Quoted from guilds100:
I assumed it was just Novus 1 which is why I asked because the more abrasive ones may require a waiting period. Let's see what people say. Most would probably tell you to avoid Novus 3 entirely.
Why not just clean the playfield with naptha prior to waxing? That should remove any surface contaminants before waxing.
Quoted from ArcadiusMaximus:
I watched some head to head cleaning techniques on youtube and novus gave the best results for what I'm working on. Im on williams 78 world cup that was probably never cleaned so it needed a little extra grit. Also I did some touch up around all the inserts and the novus flatten it out nicely.
When I clean with novus I never let it dry, just use a rag and wipe it up as you go area by area. Still dirty, just repeat the process.
I did wipe the novus off with a clean cloth after and didn't let it dry on the surface. I read that it had solvents in it that I can still smell on the playfield when I stick my nose to it. I used to finish guitars with lacquer and it had to pass the sniff test, no smell what so ever before continuing with the finishing process. I usually took 30 days to get to that point. I'm quite sure this wont take that long but I dont want to screw this up either. Im practicing on this machine first but I have 4 more in the hopper and want to make sure I'm doing it right.
After I clean the whole playfield with novus, I wax then, usually the same day. I have let the wax sit for several hours to overnight. Then wax off.
you're definitely playing it wrong.
Quoted from MotorCityMatt:
Then wax off
What you do on your own time is your own business.
said Mrs Miyagi....
It passed the sniff test and I gave it a coat of wax. I forgot to ask how many coats does one apply?
This. The naphtha removes everything and does not harm paint or clear pat, and evaporates super fast. Wear a mask though
Quoted from Rdoyle1978:
But does naphtha polish at all?
Not really Novus related but more of a process question.
Is there anything wrong with not using naphtha at all and just rewaxing every time?
Quoted from gjm7777:
You'd get a buildup of wax and crud after a while. Especially on EMs. I tend to wipe up more black coil gunk on them than I do on my SS games. Straight always waxing wouldn't really do a good job getting that crud out.
I tend to polish up a new-to-me game once with Novus 2, then just naphtha and re-wax every so often to keep things tidy.
Quoted from mbaumle:
Thanks,
I only have SS but i've not been using the naphtha - Not really much build up yet as I'm really careful not to get wax on posts/ramps etc.
I figured I could use the wax as a way to clean in some ways but I'll try the naphtha in between.
Sorry I meant Novus > naptha > a waxin'
That's not any different from not washing your car before waxing, all you do is grind in surface dirt. I always use naphtha before I wax. I use novus 2 when I do a complete shop followed by naphtha then wax.
Wear a mask though
This is reason enough to skip naptha. There's enough toxic crap out there without bringing it in your house to the pinball machines. Novus 2 is an abrasive. Buff with a rag after novus 2 and you are good. That will remove the novus fine. You're not pouring gallons of novus on.
Man... how much naphtha are you guys using?? Just dab some onto a rag, and wipe. I hardly smell anything when I'm cleaning. A little goes a long way. No need to saturate anything.
Naphtha contains Benzine, which is bad juju. I plan to be playing pinball for many years so I take any available measure to limit exposure.
Quoted from ryan1234:
2 coats...
Make sure Biff puts on both.
Can you wax... a coat of wax?
Quoted from Neal_W:
https://www.collectioncare.org/MSDS/naphthamsds.pdf
? It says no long term effects from inhalation, does it not? I’ve never worn a mask.. which by mask I would assume you mean something more heavy duty than a dust mask. — but regardless if you can crack a window in the pin room or limit your naphtha session to a couple minutes you shouldn’t have any issues. Totally my opinion of course, but esp. after seeing the msds I don’t see a major issue with a bit of naphtha
Quoted from Mbecker:
Respiratory irritants can affect different people different ways, and the OSHA exposure limit numbers don't mean much to me.
The bottom line is you must use chemical gloves and ventilation for safety, and common sense says always seek out a less toxic alternative when available.
I made this thread in this thread's honor: https://pinside.com/pinball/forum/topic/psa-come-on-people-down-with-napatha-up-with-novus-2
It's highly flammable even in the air, and it's terribly bad for you. Come on guys, it comes in a METAL container. It's not for cosmetic reasons, either!
I spilled it on my hands once or didn't take the glove-rule seriously (I forget), and I swear to god I tasted it in my mouth for two days. Scary experience. Could have been either from touch or from inhalation. Regardless, it stinks. Literally and figuratively.
I don't want to speak for him, but I believe even Vid recommends you wear a mask w/ Naptha
Someone blow the vid horn call
I just finished buffing off the second coat of wax. Now on to the reassembly part. I'm happy with the results and plan on using this procedure on each machine I have. This was a real pain to do but worth the effort. The blitz wax is something I've never used before and well worth the money.
The real question is why are you using Novus (a PLASTIC cleaner) to clean your pf??? And it's Novus 3 to boot!! You are removing layers of clear with every rub.
Use Simple Green or something like that to clean instead.
Quoted from Pimp77:
Simple Green
water based
There's an entire thread dedicated to this "guide to waxing" play fields. You'll learn from Vid that naptha is great for everything including putting on your breakfast cereal. myself I'm anti.
wipe. novus 2. wipe. wax.
Quoted from Neal_W:
Throwing on a pair of rubber gloves and a respirator takes seconds, and seems like a reasonable precaution when working with something like naphtha.
Respirators are cheap, and you really should have one if you do anything remotely interesting in your shop.
amazon.com link »
Get some particulate filters for sanding, sawing, etc. (far superior to the "protection" provided by a "comfort mask").
amazon.com link »
And then get VOC filters for naphtha use (and use it when you're spray painting or using other volatile chemicals).
amazon.com link »
Opinions differ, of course, but you only get one set of lungs so spending $50 to take care of them seems reasonable.
I got it all back together. It looks like a bowling alley. My cheap camera cant ever take a picture of it.
Was the shaker motor activated when you took that shot?
