Quoted from Shenanigander:Is this crazy?
Yes, that is definitely crazy. How many games are you playing per week at this point?
The playfield is still mint! There is pretty much no wear anywhere! There may be a tad of wear in the arcade scoop but I have a Mantis there. I'd have to take a closer look!
That's amazing...way to go! I know that the lifetime earnings don't reset when you update code...but not sure about total plays. Also, I can't say for sure about modern Sterns, but WPC games don't count a play until you reach ball three - so if you mulligan earlier than that, it won't be counted against you.
My LE was definitely around the high 5K (closer to 6?) mark, with the majority of the plays going on the 1.3 code.
Four disc rubbers, two disc motors, (one was just terrible) three flipper re-builds with two change of new bats, four FULL teardowns w/re-rubberings, (sling rubbers done at least 10+ times) one new scoop.
It still looked and played like a pampered game because it technically was! Changing balls sooner than later and in-between cleanings/waxing was really the key to it's youthful PF appearance.
IM-esque ball times on around 3000 of those games didn't hurt either!
Edit: Proto Cliffy from pretty much day one also installed. Shooter lane protectors went in midway through.
Quoted from NimblePin:My LE was definitely around the high 5K (closer to 6?) mark, with the majority of the plays going on the 1.3 code.
Four disc rubbers, two disc motors, three flipper re-builds with two change of new bats, four FULL teardowns w/re-rubberings, (sling rubbers done at least 10+ times) one new scoop.
Wow! I actually had to replace a flipper transistor day one from holding the flipper up too long (was on phone). Other than that I did one tear down and cleaning, had one broken diode in on the shooter lane switch. Had to pull up the upper left flipper bat once as it was dragging. But other that that I have not had to do much else.
Yeah, the full teardowns were due to the crappy white rubber I was putting in. If I had the Titan stuff four years earlier it would've probably only needed one full teardown.
Titan rings are now on everything and I couldn't be happier with all the extra free time that has been cleared up due to NOT working on games.
Quoted from ryanwanger:That's amazing...way to go! I know that the lifetime earnings don't reset when you update code...but not sure about total plays. Also, I can't say for sure about modern Sterns, but WPC games don't count a play until you reach ball three - so if you mulligan earlier than that, it won't be counted against you.
Haha thanks! So they all may be legit plays
Quoted from NimblePin:Yeah, the teardowns were due to the crappy white rubber I was putting in. If I had the Titan stuff four years earlier it would've probably only needed one full teardown.
Titan rings are now on everything and I couldn't be happier with all that extra free time I have now.
Interesting. I have never tried them? Are they like superband material?
Nope... Superbands are polyurethane, Titans are silicone; depending on which ones you get (GITD feels a tad bit stiffer IMHO) they'll play like the good "old" stuff.
Thanks to Vid's "bounce" test he did a while back comparing the HAPP rubber to the Titan, I knew it was going to blow away the current stuff I was reluctantly using.
I started with a small order, since I was still kinda gun shy from Saturn rubbers and the Superbands. I decided to put a full set on my Grand Lizard to give them a proper beatdown. The flipper rubbers alone felt waaay better than the two mentioned above and the slings/misc rubbers were surprisingly nice and active.
Having the clear variety not go completely white when stretched was also a nice bonus.
I've since tinkered with some of the other colors and have found the bounce characteristics to be pretty much the same but, the majority of my games are still done up in the traditional white, because the silicone is a breeze to clean the dirt off of. Even after months of heavy play!
Hope that helps.
Quoted from Shenanigander:Here are some pics. Playfield needs to be cleaned but this is what you can expect after 5000 plays!
That's a lot of plays! Still beautiful.
I'd recommend a cliffy for your shooter lane
Quoted from NimblePin:Nope... Superbands are polyurethane, Titans are silicone; depending on which ones you get (GITD feels a tad bit stiffer IMHO) they'll play like the good "old" stuff.
Hope that helps.
Well that is very interesting. I will have to give Titan a try. Thanks for the info!
Quoted from Jeekayjay:That's a lot of plays! Still beautiful.
Yes that is a good idea! Thanks!
Quoted from Jazman:5000 plays while it's still in the box huh? That is pretty unusual...
Just funnin' since it's no longer NIB but it is HUO...
Sweet machine. I'd like to have one someday...
Jaz
Ha, if you receive an NIB machine and it shows a 5000 play audit it might not really be NIB.
I just don't understand people that stay away from playing their pinball because of the fear of bringing the total plays up.
It's a toy! Play with it, enjoy it!
Have a beer and just have fun, that's what they where made for, not sitting there looking pretty.
(Rant over)
Keep on enjoying the game OP and have fun!
Axl
Quoted from Axl:I just don't understand people that stay away from playing their pinball because of the fear of bringing the total plays up.
(Rant over)
Axl
You haven't met any of the anal collector types that just glue toys to the game and put lights on it, and don't even have their initials on the scoreboard.
It's like an expensive dollhouse to some I guess.
People actually do that? I'm trying to roll the play count like an EM.
Everyone likes them for different reasons, and has different time to allot to them. Who cares why, the more the merrier.
That's impressive. Just curious what your top score is after all those plays. Also have you made it to Portal yet or is that a routine achievement after all the plays? Just looking for a glimmer of hope that someday I'll get to portal.
Quoted from hoby1:5000 plays on tron is like 500 plays on spiderman ......... your ok
Or 10000 on IM!
Jaz
Haha yes! I guess I didn't clarify that too well lol. You all know what I meant I think though
Quoted from Atomicboy:Mike still double flips each flip when he plays. You do the time math
Is there another method?
(Rant over)
Axl
Quoted from Deez:You haven't met any of the anal collector types that just glue toys to the game and put lights on it, and don't even have their initials on the scoreboard.
Yes everyone has their own style. I rarely mod anything. Leds if anything.
Quoted from yancy:People actually do that? I'm trying to roll the play count like an EM.
Ohhh Goal unlocked!
Quoted from west6926:That's impressive. Just curious what your top score is after all those plays. Also have you made it to Portal yet or is that a routine achievement after all the plays? Just looking for a glimmer of hope that someday I'll get to portal.
My top score is 230,000,000ish. Did that maybe a year ago and cant surpass it. Then again I'm never actually going for any point strategies. It is all about getting to sos and portal. I have got to portal about a dozen times. Left it hanging 2 times (ouch). My goal now is to beat portal. I think i have only been about 25% to achieving that at most so far.
4150 on a last-run model ("ladies" translite). That's on this firmware; think it got a couple hundred on the shipped release. Would be more but we're playing lots of Metallica lately.
Quoted from Shenanigander:Is this crazy? How many of you have this many plays on NIB or HUO modern games? I imagine the game count even resets one the latest code is installed.
I had around 4,000 plays on my IM after about 14 months of owning it. Audits were wiped when I got it. I've played it a lot less lately because it turns out our second child is a much lighter sleeper than the first was... darn it.
Quoted from goatdan:I had around 4,000 plays on my IM after about 14 months of owning it. Audits were wiped when I got it. I've played it a lot less lately because it turns out our second child is a much lighter sleeper than the first was... darn it.
Wow! 4000 in 14 months? That's a LOT of playing. Good for you!
Quoted from centerflank:Very impressive....Im only at this.....Mulligans are not allowed at my house unless you want your knuckles rapped with the 6lb paint stick.
It's mulligan city at my house, the benefits of owning the pins, I play by my own rules.
Quoted from centerflank:Very impressive....Im only at this.....Mulligans are not allowed at my house unless you want your knuckles rapped with the 6lb paint stick.IMG_0716.jpg
Nice I need one on those. Their Mulligans actually allow me to tend to my beer!
i sold mine after 3 years, with 7000-8000 games played on it, and still in very good (should i say perfect !?) state
Quoted from RipleYYY:i sold mine after 3 years, with 7000-8000 games played on it, and still in very good (should i say perfect !?) state
Wow. I'm still green compared
This was my best out of the 4+ years of ownership.
Just a handful of portals as well. Waaaaay more SOS choking than I'd like to admit.
If you can master GEM then you are well on your way to reaching portal more frequently.
Quoted from Shenanigander:Wow. I'm still green compared
in my case, i have my son who takes the half of the played games...
and for those asking about portal, same old story, quite "easy" to go there, but to beat it is really another story, seems there're only few guys on earth who finished it
btw, very nice pinball, i still miss it with no doubt
Quoted from pinballcorpse:Wow! 4000 in 14 months? That's a LOT of playing. Good for you!
It seems like it, but when the average game lasts just about 1:40 according to the audits, believe it or not it was only like two hours a week.
I like fast nasty games, and my IM is set up ridiculously awesome for my tastes. Wish Elias would let me play it or the other machines down here again!
This page was printed from https://pinside.com/pinball/forum/topic/just-passed-5000-plays-on-tron-huo-nib-is-this-rare and we tried optimising it for printing. Some page elements may have been deliberately hidden.
