Right side, from the top the first three holes are all for the red lead, DC voltage. The bottom right hole is for the red lead, measuring resistance, current (milliamps), and some voltage range I can't identify without a manual.
Left side, top hole is for the red lead, AC voltage. Bottom hole is black lead.
If this were my meter and I had no manual or someone knowledgeable to ask I would not use it. Harbor Freight sells $4 meters that are likely as accurate as what you have. https://www.harborfreight.com/7-function-digital-multimeter-92020.html
