Okay,
The game was having an issue where it would boot okay some times, and sometimes only the gi would come on. So I shotgun replaced the connectors on the PS board with trifurcon pins and connectors. When on my last connector (CN6) I was working to fast and accidently messed up the order of the wires. The four grey wires that are in the connector I accidently spaced down one extra space. Is supposed to be
empty hole
Grey - 5V
Grey - 5V
Grey - 5v
Grey/white - 12v
empty hole
What I put it as is
empty hole
empty hole
grey - 5v
grey - 5v
grey - 12v
grey white - 0
So I sent 12v to one of my 5 volt lines on the cpu. As soon as I turned the machine one, I heard a little pop noise (which I knew was bad) so I turned it off right away. The smell of burnt entered my nose and I knew I had screwed up. I relooked over my wiring and saw what I did and fixed it.
So now the MPU wont boot. The PIA and 5v line stay on constant. I do have the initial "Back to the future" sound line that plays when you power the machine up. I don't know this boot well enough to really even know where to start looking. I pulled the board and saw the 3 5v lines connect to a little round mini coil looking thing and a glass diode. Diode measures within spec so I didn't blow it.
