(Topic ID: 84644)
Just installed shaker on Star Trek Pro, loud vibrating noises
By Gannicus
10 years ago
  • 16 posts
  • 10 Pinsiders participating
  • Latest reply 10 years ago by DiggerPSU
#1 10 years ago
Installed this for my brother in his brand new Star Trek Pro, is a Stern shaker motor from the Game Room Guys.
Everything installed beautifully, I zip tied all the molex connectors at the front of the cab out of the way so they weren't resting on the plastic housing. Despite all that, once the game get's going, every time the shaker motor fires, you here a plastic buzzing sound. I've checked the plastic housing, and it is firmly seated on the shaker motor with the two provided screws. There is absolutely no play in the housing. At this point, all I can figure is the shaker arms are somehow buzzing against the plastic housing.
Is this a normal problem when installing these Stern motors?
#2 10 years ago
Definitely not normal, I installed a shaker in my Star Trek Prem, should be exactly the same, and I have no buzzing at all.
I would try it without the plastic shield in place. It's just there in case something flies off, but you should be fine to leave it off for brief testing. Will at least tell you if that's the source of the noise or not.
#3 10 years ago
Make sure you have beer seal on the lockdown bar.
#4 10 years ago
Aurich that's exactly my next troubleshooting step, but won't get another try till the weekend.
#5 10 years ago
First thing to check is the long screw that goes parallel to and above the shaker motor. This may need to be tightened, but only tighten it to the point that the vibe noise goes away. This secures the motor firmly in the bracket.
#6 10 years ago
Excellent thing to check caker137, thank you. Will check that as well.
#7 10 years ago
Isn't some cables touching the shaker ?
#8 10 years ago
Fabiofpc, I zip tied them out of the way. There was absolutely nothing touching the plastic enclosure.
#9 10 years ago
Quoted from caker137:
I believe this is only on the PBL Shaker Motor Setup.. But this might be a PBL shaker setup. Thats the only time I have seen this issue.
#10 10 years ago
I believe the shaker I installed in my ST Pro is also louder than it should be. It is rather loud itself, and also causes more audible resonances in the cabinet and backbox than I imagine it should.
Unfortunately, I'm out of luck with the two suggested adjustments I've found, as mine doesn't have a screw across the top of the bracket, and the manufacturer put Loctite on the weight's set screws (so I can't easily rebalance them without breaking that down, which I'd rather not).
I don't have a good reference point though, as the bars where I play other tables tend to be really loud. Would a kind pinsider out there with a good motor be willing to post a quick video of the shaker coil test with the glass on? I looked around, and couldn't find anything quite like that.
#11 10 years ago
You shouldn't be hearing your shaker at all with the glass on. Feel it, not hear it.
#12 10 years ago
Thanks for confirming, Aurich. That's what I suspected, unfortunately.
#13 10 years ago
Tighten the threaded long bolt that goes through the shaker housing. Just go into shaker test and tighten it until the noise goes away. 100% the problem.
#14 10 years ago
Mine doesn't have the threaded bolt, nor is it drilled for one, so that's not an option in my case.
#15 10 years ago
Quoted from bammon:
Why not break the seal and try to re-balance. Succeed or fail you can always put a drop of loctite back on... if you really need to.
#16 10 years ago
Quoted from erak:
I installed the same shaker, had the same issue, and tightening the bolt was the answer as erak says.
5,612
Lake Elsinore, CA
Filament Printing
5,750
Boulder, CO
5,700 (OBO)
Monument, CO
$ 100.00
Pin Stadium Pinball Mods
$ 6,595.00
Pinball Alley
arcade-cabinets.com
$ 110.00
6,800
Brooklyn, MI
Playfield - Plastics
Minty's Mods
Gweem's Mods
arcade-cabinets.com
$ 115.00
NO GOUGE PINBALL™
$ 99.99
Lighting - Backbox
$ 50.00
Duke Pinball
YouBentMyWookie
$ 5.00
This page was printed from https://pinside.com/pinball/forum/topic/just-installed-shaker-on-star-trek-pro-loud-vibrating-noises and we tried optimising it for printing. Some page elements may have been deliberately hidden.
