(Topic ID: 134714)
Jurassic Park T-Rex Left/Right motor wiring
By ddebuss
7 years ago
  • 8 posts
  • 4 Pinsiders participating
  • Latest reply 7 years ago by Crash
#1 7 years ago
Been restoring a Data East Jurassic Park for some time now. Still fighting with T-REX. I had a bad switch on the T-REX down switch and during the replacement both of the wires to the left right motor came loose. Soldered them back on and she hasn't been the same. I think it's wired backwards since it now is going nuts when T-rex is enabled including resets. Thought i had pictures from the restore but i can't find them. Can someone take a look and let me know if it's right or wrong. Thanks for the help! Dan
#2 7 years ago
That's the left/right motor.
#3 7 years ago
Thank you. Corrected the title. It's the left/right motor that was rewired.
#4 7 years ago
Here's a post that may help if you're still having left/right problems.
IMO, the game has a design flaw. The factory board only provides a half-rectified signal to the left/right motor--causing it to move very slowly -- sometimes too slow, so the CPU thinks there's a problem and flags the motor as non-responsive.
On a friends game, I modified the circuit board so that the l/r motor gets a full rectified signal (vs factory half-wave rectification). He is very happy with the operation of the t-rex now, and the t-rex has been working flawless since we fixed it.
https://pinside.com/pinball/forum/topic/jp-t-rex-not-moving-leftright#post-1104004
#5 7 years ago
Thanks for the great work and the great tip. I'll probably include that as an uparade to the game as a next step.
Having said that I'm still not sure it's wired right. The game and t-rex was working good except it was not eating the ball reliably. Found the switch is bad. Replaced the switch. Found these wires to the motor had come undone. Reattached them. Trex is now a mess causing resets. I believe they are backwards and would love someone to do a visual on theirs so I can eliminate that as the cause.
#6 7 years ago
Hi Dan,
Here are your requested photos of the JP Left/Right motor. I hope this helps you out.
Gord
#7 7 years ago
Hmm. Appears to wired the same as mine...
#8 7 years ago
Check the directional relay mounted underneath the playfield. If it is shorted or otherwise malfunctioning it can cause issues.
$ 6,999.00
Classic Game Rooms
Other
Decals
$ 18.95
Toys/Add-ons
$ 1.25
Mitchell Lighting
Led
4,800
Bountiful, UT
$ 65.00
G-Money Mods
Toys/Add-ons
This page was printed from https://pinside.com/pinball/forum/topic/jurassic-park-t-rex-updown-motor-wiring and we tried optimising it for printing. Some page elements may have been deliberately hidden.
