So I'm having issues with a repair. My upper right flipper when out on my Jurassic Park Machine. I check the coil and someone had installed one besides the one in the manual . So I installed a new one from stren that matched the factory one and nothing. So I did a full rebuild on the lower right. Now both are dead. I've checked all the fuses, The wiring diagrams, everything I know or have read to do. Both red light come on on the flipper board when the bottom is pressed. I need some advice on what to check or if I have messed up something. The right upper flipper was intermittent a few months ago then I had the issue where after 10mins of play the machine would freeze. I installed a new power supply and it fixed that problem but the upper never worked since.
