Trying to fix a reset issue that has come up and I read over the causes outlined in the JP resetting section here:
http://techniek.flipperwinkel.nl/desega/index2.htm#reset
Before I read through that, it seemed like one of the grounding braids in the back box was coming loose and instantly causing my reset issue. Looking closer at the wingnut that is holding the grounding braid, I see that the metal tab it is connected to floats--it isn't secured to the bottom of the back box. Is that how it's supposed to be? The pictures are of the wingnut/grounding braid/metal tab connection on both sides.
I haven't had this issue before and it doesn't seem to happen during multiball, which was one instance where the site linked above mentioned. Usually, I can play one full game and it resets at "Welcome to Jurassic Park" at the start of game #2.
