Anytime there is more than a 2 ball multi-ball (tri-ball, chaos, etc) it seems like the machine loses track of a ball. Eventually it will get to a point where you are playing with one ball but it still is in multi-ball mode. When that drains you have to wait for a ball search and then eventually it will shoot out another and you continue on. Obviously it is missing some signal but I tested and at least the lasts few trough switches work fine. I will test them all, but I figured if those were bad the game would report that as a missing ball? I am hoping this is a commonality amongst games when this happens and I can look at some diode or something.
Any tips on getting the t-rex to reliably pick up and swallow the ball? Sometimes it missing the ball entirely, sometimes it takes it but doesn't swallow. I set the game level to 6.5 deg per the manual. I haven't done anything to the t-rex since I've owned the game and usually have it turned off. Are there wear parts that should be replaced or serviced?
