(Topic ID: 116650)
Jurassic Park Left Flipper issue
By Bwheels
8 years ago
  • 14 posts
  • 5 Pinsiders participating
  • Latest reply 8 years ago by Bwheels
#1 8 years ago
Hey guys i am new to the site and have read up on a bunch of your posts. Here is my problem. When playing the game, every once and a while the left flipper will be dead. No noise, no movement nothing. If i flip the right flipper a few times it fires right back up. However, if i hold the right flipper up the left one will never come back and stays dead. Any suggestions? Thanks
#2 8 years ago
Sounds like an intermittent connection for power on the solenoid. Check power wire going to the solenoid and check the solenoid behind it in the chain.
#3 8 years ago
Thank you i will check that out. just seems weird that when i am holding the right flipper up, the left never comes back. so it must be a connecting power wire i would think.
#4 8 years ago
Bad or dirty EOS switch (normally closed) will cause this. Test by jumpering the EOS switch (safe to do because the flipper board switches to low voltage after a set amount of time no matter what).
#5 8 years ago
Yes. a bad EOS will cause the flipper not to fire. If it still does not, the flipper board inside the cabinet on the left may be bad. Check for the LED on the board. It should flash once if you press the flipper button. The right side will have 2 LEDs that flash
#6 8 years ago
Cleaned the EOS and the board seems fine. I even re soldered the flipper boatd. Just not sure why when I hold the right flippe, the left will go completely dead until I Let go if the right.
#7 8 years ago
Did you try jumpering the EOS switch to make sure it's okay? I thought mine was okay but it wasn't, I put the alligator clip jumper accross it and all my flipper problems went away. Did you check the fuse clips on the flipper board too, it's unlikely that's the problem but they are notoriously weak if they haven't been replaced yet.
#8 8 years ago
I have had several issues with my JP and they always seem to stem from the EOS switch, unfortunately these switches have to be well maintained for the flipper to do anything, I think this was configured like this because of the raptor pit, if the ball has enough force to push down the flipper it needs to re-engage the high voltage.
#9 8 years ago
Quoted from fusion301:
sounds like it may be worth just rebuilding the flippers anyway and putting new EOS on.
#10 8 years ago
Quoted from bobukcat:
i am fairly new to this, where should i jumper from?to?
#11 8 years ago
Quoted from Bwheels:
Just jumper across the two switch solder joints to ensure you have a "closed" switch.
#12 8 years ago
Thanks for the info guys!! I cleaned the EOS really good and made sure the connection was good. Been working perfectly all night!!
#13 8 years ago
It will most likely stop working after a bit of extended play, order the correct EOS switches to have on hand.
#14 8 years ago
Thank you I will right now
Decals
Trade
Machine - For Trade
Louisville, KY
5,500 (OBO)
Sugarloaf, CO
$ 18.95
This page was printed from https://pinside.com/pinball/forum/topic/jurassic-park-left-flipper-issue and we tried optimising it for printing. Some page elements may have been deliberately hidden.
