I have Jp pin I bought two years ago. The left flipper randomly quits working. If I press both flippers at the same time it will usually come back quick and then work weak for a while sometimes not firing at all. If I keep playing or turn it off and come back later it works fine. When it goes out the LED on the flip board does not light up. All the fuses appear fine on the board. I have read a ton of posts about this topic but can't seem to determine what's going on with mine. I would really appreciate anyone's input. Thank you. I added a pic of the switch.
