This JP is the machine that got me into pinball. Bought it as my first machine ~two years ago, got it real cheap, but at the time I didnt feel comfortable taking this project on, as the ower said it had "multible issues". This game went into storage and I bought a game in 100% working condition (WCS) and planed on learning as I go, which felt like a better option since I really didnt know anything about pinball or electronics in general.
Aaaaaaanyway, decided to set the game up a few days ago and take a look, not that I know that much more now than I did then
Checked all coils and fuses.
Visual inspection of the boards and the connectors.
Removed the batteries (still had the original ones, but no leakage fortunately) and added memory chip.
Everything looked okey.
Fired it up and after playing and testing as much stuff as I could the only really thing that wasnt working was the gun trigger.
Checked/reseated the connector, removed the gun and took a look at the switch. Seemed okey. When I tried it again it still wouldnt work. Smart missle was working, but not the trigger.
Decided to leave it for now.
But when I was poking around the very back of the cabinet I stumbled upon a white/brow cable that had split in two. I soldered it together again, and when I tested the trigger of the gun after that - it worked! Not really sure how that fixed it, but I was just happy it worked and I mounted the gun back to the cab.
Now the craziness begins.
I got no flashers that work.
When I push the trigger the shooter lane coil goes banans and fires a few times, along with a few other solenoids. Its really hard to keep track as it all goes so fast, but one of them is the t-rex kickout atleast. Its like the coils trigger instead of the flashers.
Both slingshots trigger the shooter lane coil.
When I cycle through flashers in test mode all I get is the solenoids kicking. Kinda like a ball search.
Flippers are normal.
Whats going on here?
After some googling it seems like bad relays can cause this. Or could it be a matrix issue?
Any insight on what I should do now is highly appreciated.
