Well. Back from vacation. Decided to open her back up. Put it in diagnostic mode and went to the switches, and took a video when I would hit the microswitch in the shooter lane it would also activate 5-6 other switches. Had to go frame by frame to write them all down. Then I checked each of those switches. The problem seemed to be in the “Herrerasaurus Low” target. Seemed the screw holding it in was maybe loose? I straightened the targets and made sure nothing else was touching and was able to run some games and didn’t appear that there were any issues during the gameplay.
However after 6-8 games then problem returned again. Checked the original culprit and there were no apparent issues. Put it back in diagnostic again and the shooter lane is now triggering 4-5 different switches than it was originally.
It was late so I stopped working on it for the night. Going to open her back up with fresh eyes and look around again. Very annoying.
One last thing, just for S&G I was checking diodes in circuit and the diode on the shooter lane microswitch is showing OL on one side when every other diode on other micro switches (when active) will show 1 and .5 respectively when swapping meter leads. There a problem with that diode?
786CF018-25BF-4B7B-AD33-282C65DEE9AE (resized).jpegBE9D014A-22D7-48AF-BAC0-C41555EAE6F8 (resized).jpeg
