I'm currently having an issue with the JP Control Room. The left scoop is not kicking the ball back out. The coil works fine and will kick the ball out after about a minute once the game detects no ball in play and cycles all of the coils.
I don't think it is registering that a ball has gone in there in the first place. I'm wondering if this could be a switch problem. There are two down there. One registers the ball went down the right scoop and the other is tied to the left scoop.
Am I right to assume I have a switch problem here since the coil works fine? I just don't want to replace the wrong parts if I can avoid it. Thank you!
