Quoted from Mikonos:Deleted post
Maybe it's just me, but I feel you need to work on your kerning (space between letters). My brain keeps reading the word SEXTINCT.
Hopefully this is the correct place to ask. I am working on a JP where it must have been hit by lightning. I replaced every board except the sound board. The game now boots up. (I will fix them afterwards, I am lucky enough to keep spares to get games working faster.)
But the coils on the brown wire are not working. The brown wire goes to PPB J6 pin 3 (p.31). The board picture on p. 65 clearly shows the board has 6 fuses. But the schematic on page 65 shows J6 p 3 going through K1 to F7. I do not have Fuse 7, 8 or 9 on this game or the replacement board I put in.
I could buy a Rottendog that has the extra 3 fuses. Is there anything else to try to get these coils to work? The game I assume worked at some previous time.
Michael
Quoted from pduffy:Hi,
Just picked up a JP project. Can anyone provide the LEDs needed to replace all lights in the game, backbox, etc...? Hoping to save some money rather than buying the kit.
Any help appreciated.
Thanks,
Pat
I did a full list, go check out my earlier post
https://pinside.com/pinball/forum/topic/jurassic-park-club/page/61#post-3620548
Thanks,
Pat
Be careful with the back box on JP. I had LEDs in mine and found i got really bad glare and hot spots. I ended up pulling most of them back out and only using a couple. I think I put one behind the sun and using a couple of red and yellow. The majority just look much better with incandescent and it really cuts down the glare. I also use incandescent blinkers in the bottom row.
Quoted from C65Mustang:The light socket under my 2 ball play area on my playfield is corroded so bad the light will barely come on. What is a good replacement for this light socket? I looked on http://www.marcospecialties.com but I was unsure of which one was the exact replacement option.
[quoted image][quoted image]
Maybe this?
https://www.marcospecialties.com/pinball-parts/077-5009-00
I use frosted warm white 1smd bulbs in my pins in my back boxes. They look awesome without the glare.
https://www.cometpinball.com/mobile/Product.aspx?ProductCode=1S
Quoted from hawkeyexx:I use frosted warm white 1smd bulbs in my pins in my back boxes. They look awesome without the glare.
I have also used the 1smd's and really like how they look, they look great in my FT. Have you ever tried the 2smd's? They are supposed to be a bit brighter but are listed as the same price. So next game I do I was contemplating using the 2smd's, but I'm not sure.
Quoted from Bugsy:I have also used the 1smd's and really like how they look, they look great in my FT. Have you ever tried the 2smd's? They are supposed to be a bit brighter but are listed as the same price. So next game I do I was contemplating using the 2smd's, but I'm not sure.
I put 2 SMDs warm white frosted in my slings and I like the extra light. It would be too much on a whole pin but it certain spots it probably makes sense.
My next order I’m going to do the 2 SMD for oranges cause the 1 SMD oranges through out noticeably less light. Same for the yellows. I usually just use warm white for orange-yellow-amber but in my WoF and BTTF they have an amberish insert so I want to make the orange look different.
I have used frosted 2smd on my Baywatch. The look awesome.
Good to know, thanks for the feedback. I will probably order a 100 pack of the 2smd's, and throw them into spots that are a bit darker than others.
Quoted from Chitownpinball:Ive been thinking I want to move all my GI back to incandescents. LEDs are just so bright and obnoxious, especially on my JP. In my T2 it makes sense, that whole move has a blue tint to it, but even with the warm white LEDs in my JP, they are too bright.
Are you using a frosted LED bulb?
20180809_131130 (resized).jpgI thought so. I will double check. My blinkers behind all the actors are incandescent, and they look great.
Quoted from modfather:If anyone has a Jurassic Park topper, I would love to custom paint it for you. I would do it for free. I want to add some color to the main areas. Similar to the paint job I did for TFTC topper. Just PM me for details. Chuck
That's VERY tempting!
Quoted from woody24:That's VERY tempting!
A couple of screws, slap it in a box , drop off at post office............and BAM , looking all badass returned in a week. Don't be scared, have trust in the ModFather.
Quoted from modfather:A couple of screws, slap it in a box , drop off at post office............and BAM , looking all badass returned in a week. Don't be scared, have trust in the ModFather.
Let’s do this.
Man if the border and international shipping wasn't such a pain in the ass these days I would be all over this. I miss the days when they just waved your though to hit the post office.
Thanks for the offers guys. I have committed to doing 2 toppers for my Pinside friends. I can't refuse an offer. The ModFather
Quoted from Wiggy:I got two broken stand up targets (the green plastic part)
Is it possible to replace the plastic or do I need to buy a new switch?
If you can find the plastic, it's possible to drill out the rivet, and install a new plastic and rivet. You would need a new rivet and rivet press, too.
I'm not sure about the availability of those plastics in the right colors, though. I recall in a custom project, I put together some similar targets with orange an yellow target plastics from Marco, but I wasn't looking for green and red, so not sure if they have them.
You'll be better off buying a new switch probably. They aren't that expensive from what I remember. Plus, if you go the rivet route, you'll need the hardware like Winter said, but you'll also need to take the thing out anyways. You most likely wouldn't be able to get the tool in there to do that actual riveting while its the target is still attached to the playfield. So if you're soldering it out, and putting it back, may as well get a new one. Plus, you'll have layers of the switch that need to be put back correctly.
Plus, yeah, I'm not for certain that I've even come across just the plastic part.
I'm thinking about taking the plunge and buying a #JP as one of my first pinball machines (a friend has one that he would sell me). The one catch is that T-Rex sound that goes off like every 5 minutes when it is not being played. Can that be turned off in the software? I know there's a new ROM (which I plan to install). Not sure if that either turns it off, or will let me.
It's one of my wife's favorite themes (she has a dino tattoo) so it would be a great surprise for her - I just want to make sure it doesn't drive us nuts going off all the time
Quoted from Chalkey:Yeah just turn off attract mode easy peasy.
Yep, Adjustment 49. Set it to OFF.
Quoted from ChadH:Yep, Adjustment 49. Set it to OFF.
Awesome! That's all I needed to know!
Hello guys did woody end up putting a list of LEDs he used to make his machine look like it does, it looks amazing and would like mine to look the same? Also its brilliant to see thay after 25 years this machine is still so relevant and so many people are still playing
Not the worst fix ever but at some point previous owner used duck tape to fix the rolloverswitch in the center scoop
The bendibillity of that piece of tape made for a lot of non registering hits.
Now she plays so mutch better.
Previously turned around the gate at the pops entrance so the ball can actualy get in in stead of drop dead down
This is the second JP i own with both this two things, leaving me to wonder how did previous owner play this game?
Hi guys sorry abit random i was looking to have some of the parts of my pinball machine powdercoated, such as the legs the side and bottom trims the gun the coin mechanism. Originally i was going to go yellow on all these parts but after seeing a few machines with this set up i figured it didn't look as good as anticipated and i found this version on a website for a company that sells pinball machines over here in the UK based in London i believe. Anyhow here are some pics of there version, the playfield is rammed with dinasours probably abit much to be honest but the color scheme looks epic.
24939-jurassic-park-pinball-machine-backbox (resized).jpg24940-jurassic-park-pinball-machine-bumpers (resized).jpg24941-jurassic-park-pinball-machine-cabinet-left (resized).jpg24942-jurassic-park-pinball-machine-cabinet-right (resized).jpg24943-jurassic-park-pinball-machine-cabinet-trim (resized).jpg24944-jurassic-park-pinball-machine-coin-door (resized).jpg24945-jurassic-park-pinball-machine-flippers (resized).jpg24946-jurassic-park-pinball-machine-in-showroom (resized).jpg24947-jurassic-park-pinball-machine-jurassic-park-gates (resized).jpg24948-jurassic-park-pinball-machine-playfied-artwork (resized).jpg24949-jurassic-park-pinball-machine-playfield-models (resized).jpg24950-jurassic-park-pinball-machine-playield (resized).jpg24951-jurassic-park-pinball-machine-pterodactyls (resized).jpg24953-jurassic-park-pinball-machine-triceratops (resized).jpg24955-jurassic-park-pinball-machine-upper-playfield (resized).jpgThats a LOT of dino's!
Like the red! but personaly i would keep the gun handle black / maybe high gloss black
The baby t-rex upper left is trying to escape from the machine
Quoted from jorro:Thats a LOT of dino's!
Yes the baby T-Rex trying to escaps looks well really good idea, and as far as the gun goes yeah would probably look better if it was left black or better still chrome plated!!!
Screenshot_20181028-085336_Samsung Internet (resized).jpgQuoted from JurassicJarvis:Hi guys sorry abit random i was looking to have some of the parts of my pinball machine powdercoated, such as the legs the side and bottom trims the gun the coin mechanism. Originally i was going to go yellow on all these parts but after seeing a few machines with this set up i figured it didn't look as good as anticipated and i found this version on a website for a company that sells pinball machines over here in the UK based in London i believe. Anyhow here are some pics of there version, the playfield is rammed with dinasours probably abit much to be honest but the color scheme looks epic.
[quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image]
Here is another variation of the red trim.
Quoted from Chalkey:That looks amazing. Have you considered red t-molding for the head?
What do you mean red t-moulding?
Quoted from Lonzo:Here is another variation of the red trim.
The red armor with back coin door / red bezel is brilliant. The red ring about the black screams "DANGER" and really matches the theme.
Red armor with red coin door and red gun is too much and makes me cringe. Most pins, I recomend powder coated armor with a chrome coin door, but the black/red really looks sweet on JP.
Scroll through the gallery of this thread for zillions of options on powder coating -
https://pinside.com/pinball/forum/topic/show-off-your-powder-coated-machines-here
Quoted from lordloss:Can someone take out one of the screws holding the two halfs of the gun together? I have a nos gun, but no hardware. So i dont know what size machine screw is needed.
Hi LL,
In the event that you haven't already seen the following excerpt from the JP manual you may want to review the 2-page PDF below.
Gord
Quoted from JurassicJarvis:Just found this really good color scheme the yellow is really nice and im loving the glossy sides, how are the sides to glossy and shiny is that down to a new decal? Is that how the decals come or do you have to treat it aswell? Thanks guys.
That yellow is really nice - makes everything else pop for sure. Fits the logo more naturally too as the red is really the accent color
This page was printed from https://pinside.com/pinball/forum/topic/jurassic-park-club/page/93 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
