(Topic ID: 80267)
Jurassic Park (DATA EAST) club
By louknees
10 years ago
  • 10,136 posts
  • 577 Pinsiders participating
  • Latest reply 7 hours ago by BMGfan
  • Topic is favorited by 238 Pinsiders
59 key posts have been marked in this topic, showing the first 10 items. (Show topic index)
There are 10,136 posts in this topic. You are on page 92 of 203.
#4551 5 years ago
Hi guys.
I just joined the club, picked up a fairly original looking JP yesterday. It is my first data east table so I'm trying to get my head around the adjustments and test functions. It is a bit different to Bally/William (which is what I am used to) took me an hour to find the volume control it has a few issues like the raptor kick back not working and some lights out etc. once I fix it all up it will be sweet. I'm looking forward to reading past posts in this club to find out what I need to know first impression is that it is a great game and my kids already love it.
14
#4552 5 years ago
Finished up the lower cabinet this weekend... Love this pic.
#4553 5 years ago
Quoted from kcZ:
Finished up the lower cabinet this weekend... Love this pic.[quoted image]
Why the hell'd you print a photograph of a motorcycle into your cabinet artwork? That's ridiculous. There's only a motorcycle in Jurassic World, not Park.
So with a cabinet like that, do you have to wax it every time you wash and wax your cars too? Nice work!
#4554 5 years ago
Dude, that looks awesome
#4555 5 years ago
Wow! Spraymax?
#4556 5 years ago
Quoted from kcZ:
smooth as butter.
#4558 5 years ago
That’s the same clear I use.
Very nice work.
#4559 5 years ago
Quoted from kcZ:
Wow, just wow.
That looks amazing.
#4560 5 years ago
Quoted from Lonzo:
Very nice work.
Do you find it to be a PITA to polish? Next time that I spray it, I'm going to try to polish at 24 hrs otherwise it seems far to hard.
#4561 5 years ago
Quoted from kcZ:
Yeah. I’m not a professional and I don’t have anything to compare it too but it takes some work but have never really had a problem. I do my cabinets and playfields. I usually spray flat so I have a pretty good finish to start with.
#4562 5 years ago
Quoted from Lonzo:
I did this last coat flat. Just seems like the pigtails from sanding are hard to buff out. This last coat, I started hand sanding with 1500 then DA 2000, 2500 & 3000 grit before I switched to the buffer. I had to work to get the pigtails out which had to be no more coarse than 2000 grit. I'll probably try a different clear after I run thru this gallon that I have.
#4563 5 years ago
This seems like a good place for this too...
Old vs new
IMG_20180918_191848 (resized).jpgIMG_20180918_191848 (resized).jpgMVIMG_20180918_191825 (resized).jpgMVIMG_20180918_191825 (resized).jpgMVIMG_20180918_192729 (resized).jpgMVIMG_20180918_192729 (resized).jpgMVIMG_20180918_193709 (resized).jpgMVIMG_20180918_193709 (resized).jpg
#4564 5 years ago
Quoted from kcZ:
Old vs new
Old vs, brand new? Or newly re-shined? If those are brand new replacement guides, you may have some people wanting some of their own as those tabs are prone to breaking. I had to have mine re-welded.
#4565 5 years ago
Quoted from woody24:
These are new cut from 304 stainless steel mirror polished. Prototypes will be on my machine then I'll start taking orders. TZ & Met to follow.
#4566 5 years ago
Dupe
#4567 5 years ago
Quoted from kcZ:
Old and new
#4568 5 years ago
Old vs. polished
20180804_092619 (resized).jpg20180804_092619 (resized).jpg20180810_173632 (resized).jpg20180810_173632 (resized).jpg
#4569 5 years ago
Quoted from kcZ:
Old vs new
I really need those guides. Let me know if you are going to sell them. Mine right side one is broken.
#4570 5 years ago
I was rebuilding my flippers today and noticed that my upper flipper did not have a EOS switch. The two lower flippers both have EOS switches.
Is that the way it should be?
Bought a 2+1 flipper kit and it came with 3 EOS switches, so whats the correct setup?
#4571 5 years ago
Quoted from Wiggy:
Correct!
#4572 5 years ago
Stock, there's nothing on them. But what I did was add two small rubbers on the ends of the two wiresforms that come down.
Quoted from tjprice222:
Mine used to do that as well. Loosen up that nut holding the rail and move it slightly to the right. When you re-tighten the nut, hold the rail because it will want to pull to the left and that’s causing the ball to go over the sling shot. Mine did not have a bumper either. Should be an easy fix.
I moved the ramp all the way to the right, which made the ball fall out less frequently, but did not eliminate the problem entirely.
Adding two post rubbers to the end of the wire form seems to be the winning ticket.
Haven't had it happen since I put them on.
Much thanks, it seems like problem solved.
#4573 5 years ago
Playfield Service Rails:
Anyone have a part number used with sucess for playfield service rails? Williams type.
Even if we can only use one in the middle like a spooky pin, it would be an upgrade.
Thanks in advance!!
#4574 5 years ago
Yeah that would be awesome. I keep putting off repairing my little service leg things that are each hanging on by one screw.
#4575 5 years ago
I bought the little feet that can prop the playfield up. I forget who makes them. I havent put them in, but I have them, lol.
#4576 5 years ago
Help please. Shoot T-rex lamp doesn't work. The red/green wire under the playfield is going nowhere after the IDC connector.
What is the location of associated diode?
#4577 5 years ago
Just received this pin. It's the east dock sign, and will fit perfectly with the game. Plus the arrow spins!
https://popvultures.xyz/product/east-dock/
4271FE39-067A-4A9D-9AD9-6FED9AA2749C-475-0000021657E2EDAF.jpeg4271FE39-067A-4A9D-9AD9-6FED9AA2749C-475-0000021657E2EDAF.jpeg
#4578 5 years ago
Quoted from Bugsy:
Tims pinball mods makes this....
https://www.timspinballmods.com/collections/jurassic-park-pinball-mods/products/jurassic-park-east-dock-sign
#4579 5 years ago
Another newbie flipper related question; Does the eos switch effect the flipper strenght on a JP in any way? Or does it work like wpc fliptronic games?
#4580 5 years ago
WPC Fliptronic...
If the ball hits the flipper to hard and causes the flipper to fall back,
the End-Of-Stroke switch should close and re-trip the circuitry and re-energize the flipper.
#4581 5 years ago
JP has a service bulletin about eos switches. They can definitely cause weak flippers in the game.
#4582 5 years ago
Quoted from Chalkey:
Where would the service bulletins be posted?
#4583 5 years ago
Quoted from C65Mustang:
There are quite a few SB's at the following URL.
http://arcarc.xmission.com/Pinball/Stern%20Service%20Bulletins/bulletins.htm
Gord
#4584 5 years ago
Is there a way to tell if the EOS switches have been replaced? I know one bulletin mentions changing them out instead of doing the board work.
#4585 5 years ago
Oddly enough changing mine to new ones somehow caused the problem
#4586 5 years ago
Service Bulletin #54
1) replace old End-Of-Stroke switch with kit
--- Update Kit 500-5821-00
--- includes E.O.S Switch and 180-5124-01 Spacer with instructions.
--- The new E.O.S. Switch is wider and has backup blades attached.
2) Replace S.S.F.B. # 520-5033-03 with new board.
--- #520-5076-00.
3) MODIFY S.S.F.B. #520-5033-03.
--- Added circuitry which prevents the failure of the flippers
--- if the E.O.S. switch fails.
#4587 5 years ago
Quoted from Wiggy:
I was just thinking if I should change my eos switches aswell when doing the fipper rebuild, but since they work I might just leave them for now.
#4588 5 years ago
Quoted from Davi:
Thanks![quoted image]
Did you get an answer?
If not, let me know and I'll take a look tonight.
#4589 5 years ago
I sent Davi photos of my pin that has been setting in the repair line for a year......I hate buying pins from folks that say that are in good working order
#4590 5 years ago
Quoted from altan:
Yes, I've got pictures from hawkeyexx. Thanks again, and also for your offer.
Now that lamp is working. Next task is to stabilize ball trough. This Data East design is a bit... Not very well done.
#4591 5 years ago
Is there anyone selling the updated ROMs?
#4592 5 years ago
Quoted from uptownsinclair:
https://pinside.com/pinball/biz/directory/1335-matt-s-basement-arcade
Awesome person burning roms
#4593 5 years ago
Old vs. 3D printed new
#4594 5 years ago
Quoted from Davi:
That thing takes a beating. I wonder how it will hold up over time. I have printed stuff for my game before but nothing that actually gets hit by the ball.
#4595 5 years ago
Quoted from Lonzo:
The material is ABS. Should not be an issue, especially at home environment.
If I have to change it... I can get a new one in 2 hours from the printer.
#4596 5 years ago
nice, can't beat the turnaround time. You should print it in translucent yellow filament that way you can light it up.
#4597 5 years ago
Quoted from mbott1701:
#4598 5 years ago
I actually went with a clear one and then used a green led under it along with a red interactive led.
#4599 5 years ago
Quoted from Davi:
Love that photo
#4600 5 years ago
Been adding a few things to the Jurassic Park and having my 7 year old son help me.
Getting him involved on doing little things has really peaked his interest in pinball.
Last week he helped put LEDs in the back box.
Tonight we replaced the captive ball with a white ball we got from MARCO so it looks like an egg.
We also put in new metal instruction cards that we got printed from Adam - member djsolzs on pinside.
Pretty happy with it and stoked my kids taking an interest like he is.
3BA7E5CF-6D6D-4F88-948D-042F1505C1CE (resized).jpeg3BA7E5CF-6D6D-4F88-948D-042F1505C1CE (resized).jpegA556CBED-28B5-4C5D-B58C-1623BA8BBF84 (resized).jpegA556CBED-28B5-4C5D-B58C-1623BA8BBF84 (resized).jpegD4BEE4DF-D6C3-4263-B2AE-FC32EA04DEB1 (resized).jpegD4BEE4DF-D6C3-4263-B2AE-FC32EA04DEB1 (resized).jpegD6A4CF16-88ED-4397-968C-3896FA4DD08D (resized).jpegD6A4CF16-88ED-4397-968C-3896FA4DD08D (resized).jpegE4F6BF94-5E9E-4770-A6FB-F77B6250F578 (resized).jpegE4F6BF94-5E9E-4770-A6FB-F77B6250F578 (resized).jpeg
Loop Combo Pinball
$ 45.00
G-Money Mods
7,000
London, ON
$ 9,499.00
Classic Game Rooms
$ 65.00
G-Money Mods
Los Angeles, CA
$ 250.00
Avid Creations Wireforms
$ 130.00
Dijohn
$ 27.95
$ 18.95
$ 18.95
$ 29.95
YouBentMyWookie
Paradise Distribution
$ 50.00
Duke Pinball
$ 49.99
$ 89.99
Maine Home Recreation
Sparky Pinball
$ 100.00
G-Money Mods
$ 29.95
$ 29.95
$ 15.95
4,500 (Firm)
Ronkonkoma, NY
This page was printed from https://pinside.com/pinball/forum/topic/jurassic-park-club/page/92 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
