Call for Help:
I bought my machine knowing the right lower flipper gets stuck on during gameplay. I first thought this was a bad EOS fix but after reading Jurassic Park Flipper Hold Issue thread I quickly realized my issue wasn't so simple based on the way EOS works in this game. I have a different problem then that thread however.
The issue is when the lower right flipper gets activated it stays activated until the end of the ball. Afterwards the game drops power to the flippers and the flipper returns home. As soon as I press the right flipper again though its stuck back on. The coil is definitely active while its stuck on because I can't push the flipper down manually.
After reading that other JP flipper thread I took a look at the flipper control board and noticed mine looked kind of crusty. Take a look at the photo... what are those resistors added to those two chips doing? Theres no way thats factory right? Did I get a dodgy hacked up FCB? Any ideas what I should try next? I can confirm the board LEDs light up when the cabinet buttons are pressed and the stuck flipper LED doesn't stay on even though the flipper is still active. I'm worried my simple flipper rebuild has turned into larger board problems.
Anyone have any ideas?
Another minor thing I noticed and not sure if its common on JP but the DMD seems very noisy. I read some posts that buying a new one fixes this on some games but theres nothing seemingly wrong with my display. It just makes a lot of electronic noise. Common or Not on JP?
