Flipper Fidelity REVIEW:
Just installed Flipper Fidelity speakers into my JP. And honestly, I don't think it was worth it. I've had a Polk external Sub connected to it for almost as long as I've had it, and that made a world of difference. Adding these FF Speakers did not.
While the back box speakers are probably better sounding and allow for a wider range of frequencies, I think it actually hurts it. The voices are now deeper, and have less treble. So it kinda sounds like there's something obstructing the sound. Like holding a towel over them. And with the external Sub, and the upgraded cabinet sub, the more bassier sounds coming from the backbox are just not needed.
And the quality of the stock sounds just aren't good enough to sound any better.
So if you don't have an external sub, get one instead of upgrading all the speakers. If you've already got an external sub, just stick with that.
Also, while the installation went smooth, the instructions could be a little better. A few points are missed. It doesn't mention that the included spacers are used for the backbox speakers. Something people can figure out, but also forget because it doesn't tell you to grab them. And how to exactly connect which wires to what for the volume control. Wasn't sure which end goes to speakers and which end goes to power, and if it doesn't matter, it should probably say so. And also what the included roll of thin tape was used for. I didn't even use that because it made no mention of it. Also says that for the sub to connect the negative, but then can either be connected to the High or Low positive. Would like to know if the results are exactly the same, or if one makes it sound different than the other.
