Can you show exactly what you did, maybe a tutorial?
If you're going with an LCD, I'd recommend going with DMD Extender or SmartDMD since they are cheaper and allow for custom color palettes.
I've had DMD Extender in my JP for a while now.
Also RGB LED panels are now available that fit exactly in place of the DMD without requiring alteration. There are a few threads here talking about them and a few people selling solutions.
Quoted from winteriscoming:I'd you're going with an LCD, I'd recommend going with DMD Extender or SmartDMD since they are cheaper and allow for custom color palettes.
But ColorDMD just released Guns N' Roses... which, surely, opens the flood gates for other Data East.
Quoted from ChadH:But ColorDMD just released Guns N' Roses... which, surely, opens the flood gates for other Data East.
I'll believe it when I see it for JP. After purchasing a couple RGB LED panels, I'd much prefer a solution with them. An LCD in JP requires removing a couple lights in the backbox and is a pain to service because the speaker panel has to be removed before the hinged light board can swing out. And the LCD is susceptible to damage during servicing (mine is cracked).
I was wrong. Bulbs didn't have to be removed.
Quoted from ChadH:I am wondering how the physicality of Guns N Roses compares to that of JP in relation to adding a ColorDMD. Anyone know?
Same?
http://www.ipdb.org/showpic.pl?id=1100&picno=41455
Here's a pic of mine without the backglass in:
Hey guys, can one of you please confirm the upper flipper coil number for me? There was a different coil in place (installed backwards, too), so I checked the manual and it says it's supposed to use a 090-5030-00 coil. I installed it and now it's blowing fuses immediately.
Update:
I think I will almost DOUBLE the amount of sounds available in the game. Mainly because I add a huge variety of Dino-Sounds straight from the movies. Had to check out how they did those - sound design IS awesome
Quoted from Endprodukt:Update:
Looking forward to upgrading JP and getting to utilize your hard work one day.
Have you parsed Lost World and JP3 for useful speech clips as well as dinosaur noises or sound effects? Malcolm and Hammond are in Lost World. Grant & Satler are in JP3.
Also, "Beyond Jurassic Park" - the 4th disc in the trilogy boxset - may be useful if you haven't viewed it.
Quoted from rubberducks:Have you parsed Lost World and JP3 for useful speech clips as well as dinosaur noises or sound effects? Malcolm and Hammond are in Lost World. Grant & Satler are in JP3.
The problem isn't all the speech samples I could get. The problem is that the game is not giving you too many "bound" events where you can actually put all of these samples.
Oh, btw:
Is anyone willing to scan three plastics for me? It's the gun-plastic in the shooter lane and the two plastics around the entrance to the bumpers. Please hit me up and I'll somehow compensate for your time.
Quoted from Endprodukt:Is anyone willing to scan three plastics for me? It's the gun-plastic in the shooter lane and the two plastics around the entrance to the bumpers. Please hit me up and I'll somehow compensate for your time.
PM me, I have scanned nearly the full set. I can send you the link.
Quoted from markp99:PM me, I have scanned nearly the full set. I can send you the link.
Definitely take Mark up on his offer as his JP plastic scans are the same scans that were used by Pinbits to create JP plastic protector sets and they turned out very nice.
Gord
My impression is that the T-Rex should roar first, then the klaxons should sound and voice over after a second or two. They should be a response to the T-Rex.
Quoted from rubberducks:My impression is that the T-Rex should roar first, then the klaxons should sound and voice over after a second or two. They should be a response to the T-Rex.
It's just an enhanced version of the original one. It works perfectly with the dmd animations and Gameplay.
I am having a problem getting my JP playfield incline set. I have 30.5 inch legs all around and with the leg levelers on the front set as low as they can go (jam nuts removed and levelers bottomed out on leg) and the rear levelers set as high as they can go (just one turn of threads above leg material) I can only get 7 degrees of incline. I would like to find out if this is normal or maybe the front legs should be the shorter 28 inch variety? Yes, my floor is level, I checked that first. I am not trusting the built in levels, I am using something better. I am measuring directly on the playfield surface. Any help is appreciated.
Thanks,
Jim
Quoted from jim5six:I am having a problem getting my JP playfield incline set. I have 30.5 inch legs all around and with the leg levelers on the front set as low as they can go (jam nuts removed and levelers bottomed out on leg) and the rear levelers set as high as they can go (just one turn of threads above leg material) I can only get 7 degrees of incline. I would like to find out if this is normal or maybe the front legs should be the shorter 28 inch variety? Yes, my floor is level, I checked that first. I am not trusting the built in levels, I am using something better. I am measuring directly on the playfield surface. Any help is appreciated.
Thanks,
Jim
Only 7°? That's pretty much all you want usually. You could get longer leg levelers if the short once are in there.
Quoted from GRB1959:Definitely take Mark up on his offer as his JP plastic scans are the same scans that were used by Pinbits to create the JP plastic protector sets and they turned out very nice.
Gord
Got 'em.
Is anyone willing to make or share a scan of the "Raptors Danger" plastic and the Plastic that is riveted around the T-Rex? That would make it complete.
I'm planing on getting the set vectorized. This might get us somewhere...without promising anything at this point.
Quoted from Endprodukt:Is anyone willing to make or share a scan of the "Raptors Danger" plastic and the Plastic that is riveted around the T-Rex? That would make it complete.
Attached is a scan of my "Raptors Danger" plastic. My scanner isn't big enough for the whole plastic so it's two scans you should be able to stitch together. Nickel is scan for size.
Quoted from Endprodukt:Only 7°? That's pretty much all you want usually. You could get longer leg levelers if the short once are in there.
I like the play at 7 degrees, yes but it doesn't seem right that i am at the end of my adjust-ability at 7 degrees. Why do they show an 8 and a 9 degree on the apron if they are unreachable? I do have the long levelers in the back
Quoted from jim5six:I like the play at 7 degrees, yes but it doesn't seem right that i am at the end of my adjust-ability at 7 degrees. Why do they show an 8 and a 9 degree on the apron if they are unreachable? I do have the long levelers in the back
Actually have the same problem. Back all the way out. Front all the way in. I think i have the short levellers though.
I totally forgot the gate. I don't have rivets or the tools. Anyone willing to get that plastic out and scan it?
Thanks,
Jim
Hi Jim,
I just confirmed and both my JP and TFTC (both DE games) have 28.5 inch legs installed. I think that you need to install the 28.5 inch legs for JP.
Gord
Quoted from Endprodukt:Got 'em.
Maybe these two will help.
Gord
Quoted from GRB1959:Maybe these two will help.
Gord
Awesome Gord. thank you very much!
Okay. Only the gate left!
Quoted from GRB1959:Hi Jim,
Gord
Thanks Gord,
If I put shorter legs all around I would have the same results since that's lowering both front and back. Thank you however for the measurements. I like knowing how games came "factory".
-Jim
Quoted from jim5six:Thanks Gord,
-Jim
My jp has the long legs.
Quoted from Endprodukt:Good news: Someone else will release JP plastics officially. Yay. Can't go into any detail but it will not take too long.
That is good news. I will most definitely purchase a set.
Gord
Quoted from Endprodukt:I have good and bad news. Bad news: I will not make the plastics. Good news: Someone else will release JP plastics officially. Yay. Can't go into any detail but it will not take too long.
That's good news in deed. Pretty much all my JP plastics are broken.
PBD or B&T A if it's in Germany?
Quoted from rubberducks:PBD or B&T A if it's in Germany?
As I said... no details yet. Sorry.
Reorchestration is at 400 files (instead of 222 originally) now. I actually did watch JP2 and 3 for you guys. You seriously owe me something. These movies are terrible and just gave me a handfull of useful samples.
If anyone wants to help out (you will need a pinsound board!) hit me up.
Edit:
Scrolling through the left SFX it's mostly beep sounds, build ups, sweeps etc... until now I don't really see a reason replacing them with other beep sounds so they may as well stay.
Can someone confirm or deny the lack of diodes on the inlane rollover Lite Dock & Lite ADV. X lamp sockets? (maybe a pic or 2)
Thanks in advance,
Lee
If a plastic set is in the offing, hopefully that means repro playfields are now possible licensing wise. JP has to be the most beaten up modern machine out there on average (given that Funhouse PFs and bits are made) ... years and years of being trashed on route, and never any repro parts or pfs produced. Maybe Mirco could do a JP pf ...
Quoted from rubberducks:If a plastic set is in the offing, hopefully that means repro playfields are now possible licensing wise. JP has to be the most beaten up modern machine out there on average (given that Funhouse PFs and bits are made) ... years and years of being trashed on route, and never any repro parts or pfs produced. Maybe Mirco could do a JP pf ...
Don't think it will happen. Look at all the actors and things from jp on the pf. You need licences for each one of them. Take a look at the plastics. They're neutral, except for the gate which has jurassic park written on them. Whole different story.
I kind of doubt m/any of the actors in question would be divas about it. 2 are dead though, so perhaps estates would be difficult. Likenesses are not that close however .... some machines seem to have avoided personal image rights yet with closer likenesses.
This page was printed from https://pinside.com/pinball/forum/topic/jurassic-park-club/page/40 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
