When it rolls over it properly, it does click. It's as if the switch is providing too much resistance and the ball isn't heavy enough to depress it sometimes.
I don't know, the balls are heavy, I doubt if it were making proper contact that it wouldn't be heavy enough to close it. I think it's a different problem....as I stated before.
Does your game give you missing ball errors?
Quoted from aobrien5:When it rolls over it properly, it does click. It's as if the switch is providing too much resistance and the ball isn't heavy enough to depress it sometimes.
If you manually push the arm of the switch down, does it go all the way down? Does it do so without too much resistance? I guess you can compare it to the next one in the line. I'm wondering if the arm is bent up too much.
When operated manually, it /seems/ fine. When I got it the arm was bent so I tried straightening it like the others to fix it, but it didn't help. Then I saw the dent in the trough, so I filed that out and it still didn't help. I do not get missing ball errors, only drain recognition. I suppose if I left it like that and turned it off/on, it would give me a missing ball.
The switches that DE used and Stern still uses are crap and problematic. I usually just replace the diode if I am having problems. That solves a lot of them, then if not just replace the switch.
For that ball trough problem like you are having, it could very well be a bad switch and it isn't 'giving way' easy enough.
I bent mine for a while which helped a bit, but didn't solve it completely. A new switch had the correct amount of "give". Not guaranteeing results, just sharing what worked (and didn't work) for me.
I've got to order some other stuff so I'll pick up a new switch too. Thanks for the advice everyone, I'll let you know how it goes.
The switch works fine, when the ball rolls over it. If you look at the picture, you can see the ball isn't rolling all the way onto the switch. That's the problem.
Well, then replacing the switch isn't gong to work is it, but if you've flattened the 'dent' and the switch still doesn't activate what can it be?
It has to be something, but yet your saying everything works, that's just not possible.
My current theory is that the switch button itself (not the arm) is gummed up and providing too much resistance for a slow rolling ball to depress it. If I open the coin door, and bump the ball onto the arm where it's supposed to lay, the switch depresses and activates fine. If I press the arm myself with my finger, it <i>seeems</i> to work fine.
Quoted from aobrien5:My current theory is that the switch button itself (not the arm) is gummed up and providing too much resistance for a slow rolling ball to depress it.
Good theory. Replace the switch.
See similar switch issue here:
So after putting a bit of time in on my newly acquired Hook, I'm now familiar with a feature that I really wish JP had: a left outlane kickback coil.
I tend to lose way more balls to the left outlane than to the right due to the opening being larger since the other side has a mini post. Seems like a kickback would really save the day. Oh well, just the dreams of a terrible JP player...
Quoted from winteriscoming:I tend to lose way more balls to the left outlane than to the right due to the opening being larger since the other side has a mini post. Seems like a kickback would really save the day. Oh well, just the dreams of a terrible JP player...
You can add a post there. There is a mark for one. I added one to improve the game play, but also to protect that plastic behind it.
Quoted from GoodToBeDad:You can add a post there. There is a mark for one. I added one to improve the game play, but also to protect that plastic behind it.
Yeah, I see the dimple for it. I guess I feel like adding one in would be considered damaging the playfield. I'd have to check, but isn't there a dimple for a center post, too?
Quoted from winteriscoming:I'd have to check, but isn't there a dimple for a center post, too?
I don't see a dimple for a center post. But a center post wouldn't be protecting anything. I didn't want the plastic by my outlane to crack.
That's just part of Jurassic Park, glass smashing outrage from a left outlane drain!
Seriously though, doesn't that shit piss you off!
Quoted from Matt_Rasmussen:That's just part of Jurassic Park, glass smashing outrage from a left outlane drain!
I swear, I sometimes just want to put a rubber band across the left outlane and close it off!
Ok, total DE noob question here... The rail system on this machine really sucks compared to Williams of the same era. Do you really have to completely lift the back end of the PF to put it back into the cabinet?
Quoted from aobrien5:Ok, total DE noob question here... The rail system on this machine really sucks compared to Williams of the same era. Do you really have to completely lift the back end of the PF to put it back into the cabinet?
Dude, totally thinking the same thing. I just picked up my JP last week and have had to fix a few small issues and I was thinking what a total PIA this is.
I cracked the plastic above the shooter lane last time trying to put it back in and that told me I must be doing something wrong.
You can push down on the front of the playfield to lift the back up, but I wouldn't recommend it. I have long arms so it's not an issue for me to just lift it up.
Quoted from winteriscoming:I swear, I sometimes just want to put a rubber band across the left outlane and close it off!
Quoted from winteriscoming:So after putting a bit of time in on my newly acquired Hook, I'm now familiar with a feature that I really wish JP had: a left outlane kickback coil.
I found that instead of permanently altering my playfield I simply put a 3/16 ring around the topmost lane guide post (whatever you call them). Easy to put on, fit really well and did a good job of making the outlanes a little less brutal.
All new Sterns are like this as well. Drives me effin' crazy. I work on my ST or LotR I just get irritated then I go work on my Judge Dredd and it is like working on a Cadillac. Not Stern/DE bashing, I just wish they would have come up with a better solution.
Quoted from DougPiranha:I just got a JP and have a question. Does your right flipper when pressed show on the switch test? Mine does not but the flipper works.
When pressing the right flipper button in just enough to fire the lower flipper, it will show on the switch test. Pressing it farther in to fire the upper flipper won't show. At least that's how mine works.
Quoted from Gov:All new Sterns are like this as well. Drives me effin' crazy. I work on my ST or LotR I just get irritated then I go work on my Judge Dredd and it is like working on a Cadillac. Not Stern/DE bashing, I just wish they would have come up with a better solution.
That's what I was thinking after putting it next to my BSD. Same year of mfr and a world of difference.
So I'm not doing it the hard way? Don't try pushing harder, just be more careful lifting?
Quick question.
Anyone know the story on why thee is no Sam Jackson on any of the art? Is it the same story as Apollo 13 and Tom Hanks?
Would have wanted at least some call out s or something.
Quoted from harbngr:Quick question.
Not sure, but there is a callout that says, "Hold on to your butt!" I'm not sure when it it says it during the game. I'm thinking there might be a couple other callouts from the character.
Quoted from aobrien5:What am I missing here?IMAG0589.jpg 216 KB
I think it just needs a regular screw there. Sometimes the things previous owners did on my games makes me scratch my head or want to punch them in the face.
Your not missing anything there. That is to deter the ball from getting stuck in the corner if it goes flying.
Really? Others have that there? Not sure if mine came that way. I don't see how a ball would get up there, though.
Ok, can someone tell me how to set the time and date on this damn thing. I looked at the manual and gone through the audits, adjustments and diags and can not seem to find it.
Quoted from ChadH:There is no Date/Time setting in JP.
OK, so the time/date when ou turn it on is the rom version date? or when the pin was released? Mine says 8/24/1993
Hey, I was wondering if anyone had an extra pair of raptor pit ball guides kicking around? both of mine are broken on the screw tab at the front. I tried some JB weld, but that didn't workout so well.
If no one has any, then the other option is going to have to try and fabricate a pair. Anyone have any experience with that? pretty sure I can do it, but any helpful pointers would be appreciated.
I feel like I need one of these to haul pins in....
http://uproxx.com/webculture/2014/04/jurassic-park-explorer/
Quoted from harbngr:Hey, I was wondering if anyone had an extra pair of raptor pit ball guides kicking around? both of mine are broken on the screw tab at the front. I tried some JB weld, but that didn't workout so well.
There was someone on here offering up his actual welding skills for stuff like this. Maybe that's a good option?
I can officially now say I own one of these guys! Taken a bit to find it, but I've tried to keep my movie themed pins in my movie themed office. I moved TAF out so people could play it more easily, but my office felt empty with just Cinema. It looks nice next to its new friend. Please ignore the fact that the person that built my house cannot use a level.
This page was printed from https://pinside.com/pinball/forum/topic/jurassic-park-club/page/2 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
