(Topic ID: 80267)
Jurassic Park (DATA EAST) club
By louknees
9 years ago
  • 9,752 posts
  • 549 Pinsiders participating
  • Latest reply 1 day ago by vec-tor
  • Topic is favorited by 229 Pinsiders
59 key posts have been marked in this topic, showing the first 10 items. (Show topic index)
There are 9,752 posts in this topic. You are on page 195 of 196.
#9701 81 days ago
Quoted from ScoobaDoo:Yes…just went through the diagnostics. All Switches are working. T-Rex is not working. Not all coils are firing either.
Have you checked all fuses? Especially F5 on power board. Weird that raptor pit is firing with flippers otherwise I'd say it's a fuse for certain.
http://www.pinballrebel.com/pinball/cards/Tech_Charts/Data_East_Jurassic_Park_Tech_Chart.pdf
#9702 81 days ago
I had a loose wire/connection on one of my poos causing me grief. TRex would work intermittently, balls would sometimes load to shooter lane, sometimes not.
I traced it down to a common colored wire (in my case red) and went from there.
Good luck!
#9703 79 days ago
Quoted from Joshjowen:
Well, well, well…..this is the F5 fuse…I would think it’s burnt…of course I don’t have any replacements. All of the other fuses look ok. Can I order these with Pinball Life?
#9704 79 days ago
Well, well, well…..this is the F5 fuse…I would think it’s burnt…of course I don’t have any replacements. All of the other fuses look ok. Can I order these with Pinball Life?[quoted image]
Yes any pinball supplier will have those, if you don't have any fuses at all then I'd order one of their variety packs and some extra random sizes. Make sure you have all fuses sizes for any machines you have listed in that link I sent. Those slow blow fuses can often not look bad at all and be toast. Double check it with your multimeter.
#9705 79 days ago
ScoobaDoo - since you’re ordering fuses and have not figured what what blew it( or them if you’re still troubleshooting), consider ordering circuit breakers of various sizes, too. They really come in handy when troubleshooting. There’s fewer things more irritating than running out of fuses while troubleshooting.
#9706 79 days ago
nearest auto parts or department store
#9707 79 days ago
Quoted from Neal_W:nearest auto parts or department store
Ace Hardware is the only place I've ever been able to find mine locally. If they have them it's limited sizes and they are expensive. I'm not in a huge market tho.
#9708 79 days ago
true, slow blow are less common
#9709 79 days ago
Glad you found it! Or at least part of the issue.
#9710 79 days ago
Quoted from Billc479:
Great idea!! I found the fuses on Marco’s site but can’t find the circuit breakers. Any other name I should look under?
#9711 79 days ago
I don't think any of the big guys carry them.
https://www.thepinballscientist.com/product/resettable-fuse-circuit-breakers-for-troubleshooting/24
#9712 79 days ago
These are what I use all the time. Solder each lug to the ends of a blown fuse. (Make sure the fuse is really blown!) They work great and are forever reusable.
amazon.com link »
#9713 79 days ago
Game is once again functional. Found the problem on the PS.
My front legs are bottomed out.
My back legs are fully extended.
My playfield sits at 6.4 degrees and it’s a float-fest.
Is there any adjustments to how the playfield sits in the cabinet that can be done? Maybe increase the playfield angle inside the cabinet?
#9714 79 days ago
Quoted from ViperTim:
You are trying to get a steeper angle? You can get longer get longer leg leveling bolts for the rear.
#9715 79 days ago
Yea I want steeper angle.
But the leg leveling bolts in the rear are long as they are… even longer one’s feels like it would make for a very unstable pin…
I measured all 4 legs and they are equal lengths.
#9716 79 days ago
Well the longer levelers are the solution I go with. You can get longer legs or do some crazy stuff
but your problem can be solved for a few bucks. You could put some floor protectors or something under the rear legs too. You don't need to move it up much to make a difference. Take out any nuts that are below the front legs too.
Adjusting how the playfield sits in the cabinet... for sure don't do that .
#9717 78 days ago
Quoted from System-J:
For those who have a Pinsound, I just uploaded a new sound package:
https://www.pinsound-community.org/index.php?/files/file/392-ost22-by-system-j/
Just chiming in again on this. I also downloaded the most recent update. This is so damn good man. I gotta believe this is top 3 pinsound packages available, if not the best. This is absolutely worth buying a Pinsound for I'd you don't have one (and Pinsound should get rid of your hum/buzz too). And also recommend either installing a subwoofer in the cabinet or splicing off and adding one underneath. It truly makes the gameplay experience better. If this was the standard sound track this game would be considered one of the all time greats imo.
I'm hearing a few call outs that could use a little volume tweaking, but that's getting picky and into absolute perfection. I've got a notepad by the game and will compile them for a bit. I'll look into doing it myself too and share with you. Ive figured out how to adjust altsound files on my virtual cabinet but not in pinsound yet.
#9718 67 days ago
F5 fuse blown again…where do I go from here?!?!?
#9719 67 days ago
How much have you played it since it blew before? Did you lift the playfield or open backbox recently before it blew again? What was going on right before it blew?
#9720 67 days ago
I replaced the fuse, then turned it on, only to find out that the new fuse didn’t solve the problem. Checked the new fuse and saw it was blown also….
#9721 66 days ago
I posted on FB group too...
Ordered this toy, ripped the gate out, hacked it up. Even has lights (i inserted a red film that I had to make it look more like fire) Fits perfect!
amazon.com link »
325929970_901677827685499_1266358089467099494_n (resized).jpg326117231_897641741365605_8575726414018919838_n (resized).jpg
#9722 59 days ago
The flames would look cool with some LED flame bulbs behind it.
amazon.com link »
Maybe somebody makes smaller, pinball ones that flicker.
#9723 51 days ago
Hi, i have a JP for about 6 months now, working fine.
but now since few days i have some issues, i always play 5 ball's.
and sometimes when i lost my ball (between 2 flippers), the game doesn't always realize it.
Then al the kickouts are going on to locate the ball, after the Dino is try to eat the ball, then af few seconds the kickouts are going again and it stay in that loop.
only thing i can do is reset.
What can this be?
#9724 51 days ago
Quoted from Thunder1001:
What can this be?
I'd start with trough switch or diode on trough switch.
Going into the service menu, eject all the balls and in the service menu again go to the switch test and actuate the trough units one by one.
#9725 51 days ago
Quoted from gdonovan:
Hi,
i did some research, and i figured out that switch 58 always actief is, it's the brachiarsuarus target that seems to be a little stuck.
could that be a reason that the game is a little confused sometimes when i loose the ball between the flippers?
cause the 6 ball switches are working fine
#9726 50 days ago
Seems like that would be a little surprising, but adjusting a switch is one of the easier issues to solve, so definitely start by fixing that and see if the issue goes away.
#9727 48 days ago
Hello everyone
To improve the problem of my pinball bat (sometimes lose power) I made the change at the EOS, I soldered together the wires from the left side where there is only one pinball bat and now I have more problems on the right side, I have to make the change both on the right and on the left?
Thank you
#9728 48 days ago
Quoted from jamex:
Hello everyone
Thank you
There is a technical service bulletin regarding this issue. The EOS switches on your game must be replaced with #500-5821-00 in order to fix this issue. I have first hand experience with this resolving this same issue.
#9729 48 days ago
Quoted from mikespins:
I have already made this change and made the change also on the flipper Board as indicated by SB 54 Data East And I didn't solve the problem. Now I want to try to exclude the EOS, the change must be made on both flipper bat? Thanks
#9730 40 days ago
What are you guys using for a keychain for the coindoor for DE JP? Anyone have any links to buy?
#9731 40 days ago
Can't go wrong with a JP prop badge from Amazon.
#9732 39 days ago
Hello Everyone,
I'm checking to see if there is enough interest to run another Data East opto board batch for 2023.
Details:
https://pinside.com/pinball/forum/topic/interest-check-data-east-ball-trough-opto-board-
Thanks.
#9733 39 days ago
Quoted from Davi:
Hello Everyone,
Details:
Thanks.
I would definitely grab one.
#9734 37 days ago
Quoted from Davi:
Hello Everyone,
Details:
Thanks.
I’m in for one.
#9735 22 days ago
Edit: Tried the “data east speaker noice-ideas for a cure”-device and it didn’t help. ChanceKJ suspected that I need to do a power rebuild. Does anybody knows if this so will help with dmd buzz?
Quoted from Preacher:
Yeah, it´s time for another hum issue post.
I've read somewhere that Data east machines hums because for three different reasons:
1. Speaker hum. often ground loop issues, fixes can be float the boards, remove ground to speakers or get one of ChanceKJ devices found in the grand Data East speaker noise - ideas for a cure thread.
2. Dmd hum
3. lamps
I've got both first and second issue on my JP. I´m planning to get the pinsound board and that will hopeful fix my speaker hum issue (tried to float the sound board (but not the power board) and removed the grounds from the speaker, didn´t help).
And its kinda low compared to dmd hum.
But is there a "easy" fix to the DMD-hum except change dmd? Prices for new DMD:s is a bit steep and i rather put my meager funds in the pinsound.
/J
#9736 22 days ago
Nope. The ChanceKJ device works very well. On a friends game we floated the sound board and used the humbucker, and the (non DMD) noise is gone.
Using an external power supply to the sound board eliminates the noise too, but neither solutions eliminate the DMD noise. I'd use the humbucker + floating the board over an external power supply, because another power supply feels like such a drastic measure. But in some cases it may be the only cure.
Bottom Line: IMO the only way to eliminate DMD noise is to replace the DMD.
#9737 21 days ago
Thanks for the reply!
Yeah, I’ve read a lot about the speaker hum but there seems to be very little info of how to fix dmd hum. I was hoping there was a cheaper way than to replace it.
/J
#9738 21 days ago
So I'm sure it has been covered previously, but I just can't seem to find the thread. What is the adjustment to be made with T-Rex when he won't bend down far enough to pick up the ball? Diagnostics at the start of the game seem to indicate he is moving fine, but when the time comes, the ball always slips out because he never bends down completely. He moves fine when testing manually in Diagnostics as well. Thanks for your help!
#9739 21 days ago
Quoted from Marathonman845:
This is the Bible for the t-rex:
https://www.marcospecialties.com/pinball-parts-blog/wp-content/uploads/2014/12/039A_SB.pdf
Go into switch test and see what it tells you (this is different than the diagnostics on power-up). Report findings back here if you need help.
That said, based on reading this thread for a few years, if he isn't going down all the way it seems to be because the cable that runs through the t-rex has become frayed. One example here: https://pinside.com/pinball/forum/topic/jurassic-park-club/page/179#post-6485382
#9740 21 days ago
I had the same thing happening. I replaced the spring on the bottom.
#9741 19 days ago
Quoted from scootss:
Quoted from JIM_Z:
Thanks for your thought/suggestions on this, guys! I'll check these.
#9742 8 days ago
Can someone tell me what wire gives power to the circled lights in the attached image from the backbox. I have a break somewhere and forgot what wire I needed to replace.
#9743 4 days ago
Quoted from Socashi:
Looks like I found the break in the wire.
#9744 3 days ago
Hey JP Fans
I am having a problem with my Jurassic Park Data East T-Rex. He bends down to eat the ball, swallows it, then lowers then chomps. What’s causes the chomps, is it a switch?
Just put teeth on and without the head cover, works fine. With the teeth, no so much. Any suggestions? It was working fine with the teeth, now it’s off again.
Weird…
#9745 3 days ago
Quoted from MMarks3:
So is he eating the ball successfully? After coming back up he SHOULD do a few chomps - I think it is to show him "chewing"
Here's the full guide for the t-rex. Super helpful in troubleshooting any issues.
If its still not working, a video may help us troubleshoot.
#9746 3 days ago
My biggest questions what makes the T-Rex chomp? Is it a switch or in the chip?
#9747 3 days ago
In order for it to pick up the ball, it needs to find the center and down switches. This fires and holds the solenoid.
In order for it to swallow the ball, it needs to find the up switch. This releases the solenoid.
I think it can chomp (open and close quickly - fire/release solenoid) in any up position.
The chip/program is doing it based on those switches being activated.
The switch test / diagnostics for the t-Rex can help give you more troubleshooting info.
#9748 2 days ago
He eats the ball-check
He raises up and swallows-check
No Chomp-
Lowers Again - tries to eat again-greedy SOB, stays there as if the phasers got him
Or
Raises up-check
Chomps-check
Swallows-check
Then goes down again-fail
Comes back up
Or
Raises up-check
Chomps-check
Swallows-check
All good
If anything he’s inconsistent
Which board would this be, I can check the soccer joints
#9749 2 days ago
amazon.com link »[quoted image][quoted image]
Did you have to change the wiring in any way when you installed these or did you just chain the wires to the lights under the playfield?
#9750 2 days ago
There are two relay boards under the playfield that control the up/down and left/right movement. Those are known for having cold solder joints. That could be your problem. Boards look like this:
4,800
Bountiful, UT
$ 399.95
Pin Stadium Pinball Mods
Led
$ 65.00
G-Money Mods
Toys/Add-ons
Arcade Upkeep
Other
This page was printed from https://pinside.com/pinball/forum/topic/jurassic-park-club/page/195 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
