(Topic ID: 80267)
Jurassic Park (DATA EAST) club
By louknees
10 years ago
  • 10,136 posts
  • 577 Pinsiders participating
  • Latest reply 7 hours ago by BMGfan
  • Topic is favorited by 238 Pinsiders
59 key posts have been marked in this topic, showing the first 10 items. (Show topic index)
There are 10,136 posts in this topic. You are on page 182 of 203.
#9051 2 years ago
Quoted from Billc479:
The short answer is yes.
Check the “Z” connector for burned pins. I’ve attached two pics to show what I’m referring to. On my machine, part of the gi was out because of a bad in in the connector.
Follow the cable from the door, you should see the connector.
[quoted image][quoted image]
The GI is starting from CN8 from Power supply and splits to the backbox via Z connector and playfield?
I only have GI in the back part of the playfield starting from the 3th flipper.
The front part of the playfield and backbox still out.
Could this be a broken wire or diode?
Thanks.
#9052 2 years ago
Really starting to hate this machine.
GI still out, a lot of switches not triggering and when I trigger left slingshot it triggers als left pop bumper and when I trigger right outlane it triggers another switch.
Pffffffff
#9053 2 years ago
Quoted from Toine79:
Thanks.
1) Power flows out of the power supply connector to the PPB and then out to the playfield and backglass.
2) Check to make sure you have power flowing out of the power supply board (bad solder joints and burned connector common) and check power flowing out of the PPB past the fuses. (bad solder joints and burned connector common) its a very simple circuit.
4 power lines (and returns) come out of the power supply board, go through the PPB and the 4 fuses and from there to various locations.
#9054 2 years ago
Quoted from gdonovan:
4 power lines (and returns) come out of the power supply board, go through the PPB and the 4 fuses and from there to various locations. [quoted image]
Thanks but how do I check it?
Via DMM on the back of the boards?
Via the connectors?
Machine powered on or off?
#9055 2 years ago
Via the connectors?
With a meter with the machine on, via the connectors is fine till you find a break.
Have you used a meter to check the fuses?
Burned connectors on Data East are so common I keep them and new terminals in stock. Change to led lighting after repair to prolong life of the connectors.
#9056 2 years ago
GI fixed on the playfield. F4 holder had wacky connection together with J5 on PPB
Sometimes when I power on the machine the under row of the backbox bulbs go on for half a second.
Backbox still dark
#9057 2 years ago
Backbox still dark
Follow the power, back box connector at the hinge known for getting toasted. Try wiggling the connector there to see if it flickers on and off.
#9058 2 years ago
Could you give me a picture of that connector please?
Already Thanks for the info.
#9059 2 years ago
Note the crispy colors on the connector.
#9060 2 years ago
Note the Z connector between the connectors. In that example picture, its possible those pins in the Z connector are toast and you would need a new connector.
#9061 2 years ago
Problem solved.
It was a combination of the wires not touching the pin in the connector and the power supply board that was loose in the backbox.
Now figuring out the problem with the ghost switches
Thanks for helping me with this GI
#9062 2 years ago
Once again coming for some help, I rebuilt the upper right flipper and its working great now. I also changed the bats on both the bottom flippers, then after a while the bottom right flipper stopped working. When I hit the flipper button the top flipper will fire but the bottom one will not. I tried to clean the EOS contacts but that didnt seem to help. Here are some pics of the coil the connection looks a little sloppy but everything is secure. Any advice on where to start troubleshooting?
Image from iOS (2) (resized).jpgImage from iOS (2) (resized).jpgImage from iOS (3) (resized).jpgImage from iOS (3) (resized).jpgImage from iOS (4) (resized).jpgImage from iOS (4) (resized).jpg
#9063 2 years ago
#9064 2 years ago
Quoted from KneeKickLou:
Looks like you need to add more heat/solder to those coil tabs/wires.
Have a look at your flipper button leaf switch.
#9065 2 years ago
Well desoldered all the connections to the flipper and resoldered them and it seems to be working again. Thanks for the help again everyone
#9066 2 years ago
I joined the club last week. Excited to own one. Playfield is in great shape, Add on and mod time. What fun mods has everyone done? My T-Rex has the Teeth mod already, so happy about that.
Conrad
#9067 2 years ago
Does anyone have detailed photos of the Trex mech removed? Trying to refurbish mine and it appears an operator didn’t do a good job in the past and used random hardware.
#9068 2 years ago
Quoted from C_Presley:
A fellow northwest Ohio pin head, if you search this thread for Rex there are a lot good pictures I was able to get mine working from those, if there is anything else specific I might be able to get some later tonight.
#9069 2 years ago
Could somebody help me with a picture of the correct wiring for C8 on the power supply.
707A6DD6-EC1A-4911-86AD-19D619F3D017 (resized).jpeg707A6DD6-EC1A-4911-86AD-19D619F3D017 (resized).jpeg
#9070 2 years ago
Ohhh nevermind… found them in this thread
17BD3F28-22B6-4776-86EA-A9529C041BC5 (resized).jpeg17BD3F28-22B6-4776-86EA-A9529C041BC5 (resized).jpegE4494B00-EB93-44BF-9490-CAD592812D16 (resized).jpegE4494B00-EB93-44BF-9490-CAD592812D16 (resized).jpeg
#9071 2 years ago
Here is a clearer photo.
Your CN1 got hot, so keep an eye on that.
#9072 2 years ago
Quoted from toasterman04:
Be careful with those cheap batteries on that board. I always put Lithium in them now to prevent leakage. Or move it off board or best yet NVRAM
#9073 2 years ago
Quoted from Conrad:
DE is so easy to swap out that I keep NVRAM in stock.
Two things happen when a DE shows up at my house- LED's across the board and NVRAM for the MPU.
$20 for NVRAM is cheap insurance.
#9074 2 years ago
I put NVRAM in all mine. But some people don't want to go that mile. So I always tell them atleast put lithium AA's in it so we don't' see destroyed boards.
#9075 2 years ago
Quoted from Conrad:
$20 or $400 when the board is turned to junk IF you can find one for sale.
Feeling lucky?
One of the NE board members was crying the blues when they were tardy changing batteries and a Whirlwind MPU was wiped out.
#9076 2 years ago
Anyone happen to have an extra control room scoop plastic they would be willing to sell?
#9077 2 years ago
Hi, i'm a noob so excuse me in case i'm possibly asking the obvious. i've got a malfunction with the switch under the "A" hole, i had an unsoldered cable and i soldered it in place..just to note that it actually doesn't work and incidentally it's the only switch in the whole machine that has not a diode across the two distant connectors. all of them have a green cable in the middle, and a white/striped one on the inner side, and a diode across the exteral third connector. I assume there should be a diode there too, correct? no trace of it. And, what diode should i use? i read that 1N4004 or 1N4007 should be fine is it correct? thanks a lot in advance.
#9078 2 years ago
Quoted from Michele_Caletti:
I believe the diode is mounted off to the side since that switch gets a lot of vibration/impacts.
#9079 2 years ago
Quoted from Neal_W:
Let me reformulate: there is no diode on this switch in any position, the one at its immediate left has it. If you have the machine can you please check?
#9080 2 years ago
Here is a photo of mine which does have a diode on the switch. I recall that some also have the diode mounted close nearby instead.
(photo is mirror image, since the camera was pointed straight up?)
#9081 2 years ago
Quoted from Neal_W:
You mean rotated 180° right? Ok so diode present on both, mine is missing the (in your picture) left one. Any guess if a 1N4007 would be fine? Thanks a lot!
#9082 2 years ago
yup, thats it. always weird to visualize when you stick the camera in the coin door.
(rotated like the playfield is up: )
#9083 2 years ago
Quoted from Neal_W:
Thanks again, any hint on the diode type?
#9084 2 years ago
#9085 2 years ago
after some extensive search i read that the correct would be 1N4004 but i've ordered a bunch of mixed types, i'll try this first, thanks to you all!
#9086 2 years ago
It's all smooth now - for that switch at least!
Now another possibly noob question: when i turn on the pinball sometimes it makes go down the central switch of the floor (not the one of the whole house, for maximun watts reached, just a local safety switch) or sometimes looks like there's a power issue (screen not working fine, some lights off..)
But, if i turn off everything on the floor it works fine.
The more stuff i have on the more it's likely that it would "malfunction" or make the power shut down.
i have a 3KW/h supply, isn't it powerful enough? could it be a ground issue? anyone having same problem?
thanks and a happy multiball year to everyone!
#9087 2 years ago
It sounds like you have low voltage when other devices are turned on. Another thing to check, breakers tend to get weak after they trip (open) many times. It is possible your breaker is weak.
Your 3KW source should allow you to pull about 13 amps - assuming 220 VAC. I don't know what the surge current is when powering up JP - its possible you reach the trip point with other stuff on. Try varying the starting sequence of what you turn on first - JP, then jukebox, then mood lights, etc. See if changing the sequence reduces your problems.
#9088 2 years ago
JP is less than 1kw so you need an electrician to check what the power issue is there. If you have a lamp plugged in there, does it go dim when things are turned on?
#9089 2 years ago
if i turn on the JP and then all else, it works. The opposite, quite not. I don't try intentionally the extreme, like almost--too-much on and then JP. But if it starts alone, it works. I don't see lights going dim, just the more stuff it's on, the more likely the JP will work bad at start. yesterday i was sure it was blown, with many lights off, today with basically all off on this floor, flawless.
(unfortunately of luckily i don't have a juke box )
#9090 2 years ago
Just for grins, do you have an amp meter to check what JP is pulling? An analog meter is best to see if you have a high surge current.
Have you checked all of your power supply voltages, including the amount of AC ripple on the DC side?
#9091 2 years ago
I've had this too, solved by this https://www.flippers.be/basics/101_sys11_house_fuse_trips.html
Please be carefull when working in the area where the main voltage is present, disconnect the machine from the outlet!
#9092 2 years ago
Quoted from BuckNaked:
thanks, i see that this place is a great source of information and with really great people! So at least it's good to know that it's not indicating a faulty pinball, thanks!
#9093 2 years ago
I'm trying to see what diode is on these bulbs above the power shed and the jurassic park ramp plus the GI spotlight. None of these lights are working and I have no power to them. But going below and tracing the wires I see the two wire blocks they are soldered on with diodes. Those blocks have power. So I'm sure it's these diodes. Before desoldering them to see what the number is. Does anyone know what diode they are?
#9094 2 years ago
Quoted from Conrad:
Diode values are not in the manual as far as i can see, and the writings on the diods are to tiny that you'd better take it off to see. If it's readable, some seem to be very rough on mine.
Try reading through here: https://pinwiki.com/wiki/index.php?title=Data_East/Sega
#9095 2 years ago
Well in my previous post about my issues i've been too optimistic. regardless of what's running in the house now i get:
*audio, game, bumpers, switches, all OK
*many lights on the board, smart missile and start button off.
*screen with vertical lines only
could it be power issues? i might be wrong but involving both lights and screen.. doesn't seem a screen-specific issue. Anything to look into?
thanks in advance.
#9096 2 years ago
All the test points on the power supply board OK?
#9097 2 years ago
Quoted from Neal_W:
I turned out to be noober than expected: i opened the back panel, and disconnected and reconnected all the plugs from the boards. None seemed loose, but at first attempt the machine was OK EXCEPT the sound effects were played in random order. Done it all again, and it seems to be fine. After all it's 29 years old, and there are tons of connections... and it vibrates and shakes like hell. No surprise some connections get loose.
#9098 2 years ago
Random intermittent issues are often caused by ribbon cables. If reseating them does not correct it, next replace the ribbon cable. In this case, the ribbon cable going to the sound board.
#9099 2 years ago
So its been about a month since I picked up my JP and I think I've finally got everything going smooth. NVRAM and Chad code installed, flippers rebuilt, T-Rex working (up and down at least), all bulbs that were out replaced, new titan rubbers, couple broken plastics mended, DIY Pinstadiums installed, drop targets adjusted and finally playfield and wireforms cleaned and waxed. Now to bump up these rookie score numbers
#9100 2 years ago
Looking good. Maybe get some cliffys on those scoops.
Have you gotten to System Failure yet? It's a fun mode and still makes me smile every time I get there.
$ 27.95
$ 89.99
Maine Home Recreation
$ 29.95
$ 1.00
$ 65.00
G-Money Mods
$ 9,499.00
Classic Game Rooms
$ 185.00
Sparky Pinball
$ 29.95
arcade-cabinets.com
$ 100.00
G-Money Mods
4,500 (Firm)
Ronkonkoma, NY
$ 15.95
YouBentMyWookie
Paradise Distribution
7,000
London, ON
$ 259.99
Los Angeles, CA
$ 130.00
Dijohn
Loop Combo Pinball
$ 45.00
G-Money Mods
$ 250.00
Avid Creations Wireforms
$ 49.99
FlipMods
$ 99.00
Loop Combo Pinball
This page was printed from https://pinside.com/pinball/forum/topic/jurassic-park-club/page/182 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
