Just finished my "shop" job. Replaced a lot of parts. It's almost like new again. Flippers are strong. Almost too strong. But have a couple issues that developed after I did my shop job, and wondered if you guys could help me out. Maybe I need to start a new thread?
The machine worked before I started working on it, so I know I must have bumped something loose.
The Right VUK and the Autoplunger don't work. I tried to look in the manual to see if I could track down some points of contacts. It appears that they both share a common cable. But I really don't know where to look for the issues. I reflowed solder on both coils, but nothing.
Could someone take a photo of their VUK coil? Or tell me which wire goes to which end. I may have put the wires on backwards. It was the only coil I forgot to take a photo of before I took it off to rebuild the VUK.
I'm guessing the VUK and autoplunger is a connected issues.
But as I was testing out the game, the left flipper died on me. It was almost like I wasn't pushing the flipper button in far enough, or was making very weak connections. Visual inspection shows the flipper button leaf switch is making full connection. I reflowed solder on the coil itself. But was acting like the batteries dieing in a flashlight. Is this a sign of a coil going bad? Or could it be something else?
