(Topic ID: 80267)
Jurassic Park (DATA EAST) club
By louknees
6 years ago
  • 7,407 posts
  • 431 Pinsiders participating
  • Latest reply 3 hours ago by jamex
  • Topic is favorited by 185 Pinsiders
There have been 1,751 images uploaded to this topic. (View topic image gallery).
57 key posts have been marked in this topic, showing the first 20 (Show topic index)
There are 7407 posts in this topic. You are on page 144 of 149.
#7151 67 days ago
I thought I'd give everyone an update on the new PinSound shaker for Jurassic Park. I just finished programming the shakerization for the game and have delivered it to PinSound. I'm sure the guys will have it integrated in a few days or less, so if you've been wanting an updated shaker for your Jurassic Park then now is the time to order just in time to treaty yourself for Christmas.
#7152 67 days ago
Quoted from jamex:
My JP resets very often (once the word slam tilt appeared, the others restart or the screen remains off while the lights of the playfield turned on for a few minutes and then restarts) I think it depends on the 5v right? What are the components to replace on the power supply to restore the 5v? I'm not familiar with electronics but I'm handy with the welder
Have you first cheked the , door slam tilt?
#7153 67 days ago
Just got Data East Jurassic Park as my first pin after much looking (and saving). The game is great however the Trex has had issues since bringing it home. I’m hoping someone here can help... the t-Rex left switch isn’t being recognized when I engage it. I replaced the switch and still nothing.
Also, the trex up-down motor wasn’t working and saw that it had the cables pulled out of the motor and since I wasnt sure how they connected I bought a new up-down motor. Up-down still isn’t working with the new motor installed. Any ideas?
#7154 67 days ago
Quoted from Mikew492:
Also, the trex up-down motor wasn’t working and saw that it had the cables pulled out of the motor and since I wasnt sure how they connected I bought a new up-down motor. Up-down still isn’t working with the new motor installed. Any ideas?[quoted image]
First of all, congrats on your first pin and welcome to the wormhole that will suck you in.
As far as the T-Rex goes, there are all kinds of issues documented in this thread and others. My first advice would be to search the term within this thread and then on Pinside as a whole to read the issues others have had.
Second, have you gone into service modes to ensure that the T-Rex features are enabled? It is common for the T-Rex to malfunction, so the software allows you to turn off various aspects of it's movement.
If you don't have a manual, you can download one here: https://www.ipdb.org/search.pl?any=jurassic+park&search=Search+Database&searchtype=quick#1343
#7155 67 days ago
Quoted from jorro:
Yes, i have cheked the door slam tilt, this isn't the problem
#7156 66 days ago
Quoted from Mr_Tantrum:
Thanks for the welcome! I did go into diagnostics for the t-Rex and when trying to engage up-down movement I hear the relay click but no motor movement. One of the threads (which I’ve been searching through) mentioned to reflow the relay board to fix movement issues so I’m going to try that.
That doesn’t explain the left t-rex switch not working though which I replaced and it still doesn’t work. I’m wondering if it may be a shot diode connected to the switch but I’m really grasping at straws with it...
#7157 66 days ago
You'll need to get familiar with using a multi-meter to test voltages, continuity, etc. Best first step is knowing if power is getting to the part or not. Sometimes things can be easy to track, and other times more difficult. My T-rex diagnoses took a month or more before I figured it out with tremendous support from other JP owners. In the end, I had to replace a couple of components on my power driver board.
#7158 66 days ago
I will test tonight to see if there’s power going to the left switch. I’m hoping that fixing the switch issue will solve the up-down motor not working.
Do you know if it matters The order in which the two up-down motor wires plug into the connector? They’re both yellow.
#7159 66 days ago
Full disclosure in that electronics are not my strong suit. Posting pics and asking specific questions here in the owners thread is best. Won’t be home until later tonight, but may already be some good pics in the thread that answer your question.
#7160 66 days ago
I’ve started to research switch matrix and what’s really interesting is that there are three switches that fail in diagnostics and they are all next to each other in the same matrix row. I wonder if it’s a faulty diode or wiring between these three switches. Row 8, number 24, 32, and 40.
#7161 66 days ago
#7162 66 days ago
Likely a problem with the wire that goes to that row: Gray with white dots.
Probably came loose from one switch which makes the rest down the line not work also. Follow the wire and check it, starting at those switches.
#7163 63 days ago
So I posted a couple of weeks ago about my auto launcher being sluggish. Now the auto launcher has stopped completely after a game a couple of nights ago. I checked the fuses, coil , reflowed the wires on the coil. Nothing. I went into the coil test and can't get it to fire. All other coils are firing. I've got guest coming over Saturday itching to play. Help!
#7164 63 days ago
Quoted from edward472:
Picture of the mech please, can you manualy move the plunger in the coil? How is the coil bushing
Have you checked the switch matrix, the wireing and conector and pins at the boards?
#7165 62 days ago
Quoted from jorro:
The coil is fine. Its a coil not a switch so I don't need to check the switch matrix. The connectors on the ppb are fine. I reseated them.
#7166 62 days ago
There is a switch in the shooter lane. If the ball is not detected on that switch, it may not auto plunge.
#7167 62 days ago
Quoted from Neal_W:
Even during the coil test?
#7168 62 days ago
No, if it does not operate during the coil test, its not the switch.
#7169 62 days ago
Quoted from Neal_W:
That's what I thought. I'm starting to think it the transistor on the PPB
#7170 62 days ago
I have never worked on that, but I enjoy electronics. It appears it is driven by Q5 which gets its signal from D3.
Also, do you have the 50v at the coil?
#7171 62 days ago
Would there be an issue adding starpost lights to this game because of the metal washers? I'm thinking the washers could potentially short out the lights?
#7172 62 days ago
Quoted from gweempose:
Are you referring to the DE JP or the new stern JP?
My DEJP doesnt have or need metal washers and my stern JP doesnt necessarily NEED them so you can just take them off either way.
You can buy rubber or felt washers if you want to keep some on.
But to answer your question yes I would be wary of installing the lights with metal washers.
You could always contact @Ryanwagner from comet and ask him, he is very responsive.
#7173 62 days ago
Quoted from J-Freeze:
Oops! I have the wrong thread. I was referring to the new Stern JP. They have metal washers installed form the factory which I'm assuming are to address the pooling in the clear. Thanks for the response anyway!
#7174 62 days ago
Why is my game skipping past a bunch of settings in the adjustments? Im trying to turn free play off, which is adjustment 30, and my game goes from 19 to 99. But when I go backwards its there. W t f
#7175 62 days ago
Quoted from Chitownpinball:
That's normal to make it faster. You can also turn on 'extended list'.
Here are my notes on the goofy DE 3 menu buttons:
Pressing Black with the green button 'in' starts diagnostics.
Pressing Black with the green button 'out' starts Audits and Adjustments.
When in a menu, set the green in or out to go to next or previous menu item when black is pressed.
Some higher menu items are not shown unless you go backwards through the list, or 'extend list' is selected.
Start button is used to change the value, then hit next to save.
#7176 61 days ago
Quoted from Neal_W:
No power at the coil. Problem solved. Auto launch coil is daisy chained to the right VUK. The power wire for the auto launch came off the right VUK coil
#7177 60 days ago
If anyone is looking to join the club, there is a very nice looking JP for sale on FB right now, not mine, just thought I would share.
https://www.facebook.com/groups/630406413802349/permalink/1458399227669726/?sale_post_id=1458399227669726
#7178 60 days ago
Quoted from Neal_W:
Success on the left t-Rex switch! Found a wire that detached further down the chain. Soldered and now all good.
However I still have the issue with the t-Rex not moving up/down. There is a click on the relay board but no Dino movement. I took off the relay board to inspect thinking there are cold solder joints. What I found is that there’s a copper strip that was a bit charred and is hanging off the board. Is there any way to fix this or should I be on the lookout for a new relay board?
1FB499A0-FE8E-4A01-9420-5C767ECEF715 (resized).jpeg31354A90-A71E-4388-AC7F-68BDA3C75A89 (resized).jpeg
#7179 60 days ago
However I still have the issue with the t-Rex not moving up/down. There is a click on the relay board but no Dino movement. I took off the relay board to inspect thinking there are cold solder joints. What I found is that there’s a copper strip that was a bit charred and is hanging off the board. Is there any way to fix this or should I be on the lookout for a new relay board?[quoted image][quoted image]
Is there a continuity between red points?
#7180 60 days ago
Run a jumper wire from both points. That trace is clearly broken. It will be fine if there is no underlying reason it did that in the first place.
#7181 60 days ago
Also, just as Davi said you can check continuity between the two points and to verify if it broken
#7182 60 days ago
Quoted from Davi:
Is there a continuity between red points?[quoted image]
Great suggestion! There was not continuity. A small portion of the ribbon near the pin had a broken connection point. After adding some solder in that section it’s now working. T. rex I’d happily eating balls now. Thanks for pointing me in the right direction!!!
#7183 60 days ago
Quoted from kba78:
Thank you. You were both correct!
#7184 60 days ago
Hope to sand my ball trough bottom rail and get my balls queuing up properly again. I havent played my game in months.
Got some time off coming up. Fingers crossed.
#7185 60 days ago
Argh. After fixing a t-Rex switch issue, replacing a up/down motor, and fixing the up/down relay the t-Rex is finally working (thanks to multiple people on this site).
However, the last issue I am dealing with is that the t-Rex slams down on the play field and it’s starting to chip the play field. I think the issue may be that there’s no spring on the arm that the up/down motor is connected to that I’ve seen on pics from other machines. See the yellow circle where a sprint should be. Does anyone know what kind of spring is used and how to connect it? I see there’s an eye at the end of the arm but not sure how it connects on the other end.
#7186 60 days ago
Hope this helps
#7187 60 days ago
Quoted from kba78:
Hope this helps[quoted image]
Thank you! That’s the clearest picture I’ve seen so far.
#7188 60 days ago
Found out it’s called an extension spring with part no 265-5017-01. Currently out of stock everywhere I’ve looked except in Australia. Wondering is it’s worth the $20 and wait to order from AU...
#7189 60 days ago
Hi guys,
I'm joining the club today as I ve just purchased a JP to a friend of mine.
It was unused for years and needs good cleaning and some fixes....
The good thing is that the fuses are ok and the GI is working (as I have redone CN8....)
But, none of the controlled lamps is working...zero....
As I have already checked the fuses and thé connectors, what should I do next ???
The Trex jaw doesnot work. Probably a bad cool, but where is it located ?
I cant find it in the manual......
Finally, I ve round out some connectors inside the cabinet which are..not connected to anything.....why ??
Although winter has come, I hope it is not too late tout get help from Winteriscoming for thé T rex !!!!
Thx....
IMG_20191222_162103 (resized).jpgIMG_20191222_163132 (resized).jpgIMG_20191222_182013 (resized).jpgIMG_20191222_182020 (resized).jpgIMG_20191222_182028 (resized).jpgIMG_20191222_182041 (resized).jpg
#7190 60 days ago
Can always stores locally see what the have that would work the same
#7191 59 days ago
Check the bottom of your cabinet. Odd that that spring would just be missing totally.
#7192 59 days ago
Anyone have a part number for the black piece that goes between the T-Rex and play field? I included a picture and circled the are in red.
Thanks For Looking
Peter
#7193 59 days ago
Quoted from peteyhugs:
Thanks For Looking
Peter[quoted image]
Search the thread, as many have custom made them from inner tube rubber or similar.
#7194 59 days ago
I can't seem to find anything..
#7196 57 days ago
Quoted from softail:
Hi guys,
Thx....[quoted image][quoted image][quoted image][quoted image][quoted image][quoted image]
After some investigation, I do have the 5 V and 12 V.
But 0 V when measuring the fuse clips of F4 and F7.
COuld these clips be the culprits ?
#7197 55 days ago
I have a quick question. On my main board I have a column of what looks like ceramic blocks that are getting fire hot to the touch. crazy hot. Is that normal or a prelude to something bad getting ready to happen?
#7198 55 days ago
#7199 55 days ago
Quoted from Davedigger:
I have a quick question. On my main board I have a column of what looks like ceramic blocks that are getting fire hot to the touch. crazy hot. Is that normal or a prelude to something bad getting ready to happen?[quoted image][quoted image]
This is normal.
https://pinside.com/pinball/forum/topic/jurassic-park-club/page/139#post-5179598
#7200 55 days ago
Hello! May I please get some help! This has been a grail machine for me - and the wife finally let me buy one! We found one that is in great shape, mirrored blades, LED, and just in all around great shape. We got it home, and it worked perfectly. The next morning (today), I noticed that the T-Rex wasn't eating the ball anymore. Through the manual - I found a small board that seemed like it controlled part of the T-Rex, I think its the one pictured but it may be the slightly larger one. I simply removed the connections and replaced them, and the T-Rex started working again! Hooray! However - now - sadly - I started throwing the "Missing 6 ball Error" and the switch that controlled the ball trough solenoid claimed it worked(test mode), but would NOT fire the solenoid. The solenoid still will not fire, but somehow I have started down a rabbit hole and created other issues. For starters, the ball trough switch - I removed it to examine it and it fell apart in numerous pieces. I have ordered another one - but am stuck now without it.
The bigger problem (amongst many) is that now I have this music sound (T-Rex Stomp) that comes on at the beginning and will NOT STOP. It repeats, UNTIL - I hit the start game button - once that happens, it joyfully reminds me that I am "missing 6 balls" even though they are there, and then the sound goes away. The attract music plays just fine once the cycle has been completed, but if I reboot the machine, here comes the sound again.
Please help me! I am new (very) new to the pinball world, I have had 2 projects in the past and both had to be sold because I couldn't figure them out! I bought a working machine, got home with a working machine - and somehow 12 hours later - I have a non-working machine! The wife is rather bummed to have spent north of 3k and we can't even use it!
Here's a video to my sound issue!
$ 18.95
3,750
Gap, PA
PinSound
$ 399.95
Pin Stadium Pinball LEDs
